which plugs for nitrous???
Old Jul 2, 2005 | 01:29 AM
QuadCam's Avatar
what plugs are people using with a nitrous setup ? probably a 75 shot.
NGK Iridiums?
1 or 2 heat ranges colder?
any part numbers?
thanks,
Andrew
Old Jul 10, 2005 | 09:09 PM
JimG35's Avatar
Does this help? (from infiniti service manual)
Hot type spark plug is suitable when fouling occurs with standard type spark plug under conditions such as:
 Frequent engine starts
 Low ambient temperatures
Cold type spark plug is suitable when spark plug knock occurs with standard type spark plug under conditions
such as:
 Extended highway driving
 Frequent high engine revolution
CAUTION:
 Do not drop or shock spark plug.
Oil filter:
: 14.7 - 20.5 N·m (1.5 - 2.0 kg-m, 11 - 15 ft-lb)
SMA229B
SEM294A
Make NGK
Standard type PLFR5A-11
Hot type PLFR4A-11
Cold type PLFR6A-11
Gap (Nominal) : 1.1 mm (0.043 in)
Old Jul 10, 2005 | 09:43 PM
G35_TX's Avatar
One Step Colder plugs and stay away from Plats. Go with a straight copper NGK plug.
such as:
CAUTION:
Oil filter:
SMA229B
SEM294A
Make NGK
Hot type PLFR4A-11
Cold type PLFR6A-11
Old Jul 16, 2005 | 02:13 PM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
NGK Iridiums?
any part numbers?
thanks,
Andrew
I'm using regular NGK plugs 2 steps colder than stock I'm running a 100 shot
Old Jul 17, 2005 | 01:49 AM
killerlexus's Avatar
what kind of times are u getting from a 100 shot..
Old Jul 17, 2005 | 07:10 PM
NismoV35's Avatar
Never ran at the track. Plenty kills on the streets though........
Old Jul 17, 2005 | 11:22 PM
QuadCam's Avatar
are you having any problems with wheel hop when you get alot of wheel spin?
Wheel hop seems to be a problem on some G35s, mine included.
Old Jul 19, 2005 | 03:12 PM
beastie's Avatar
thread hijack
Sorry but what type of N20 set up are you running and what size jets are you using to get 100 extra rwhp. I am having tuning issues getting 75.
Old Jun 29, 2020 | 07:49 PM
Arturo Mireles's Avatar
Blue g35
where did you find those spark plugs?
Old Jun 30, 2020 | 03:35 AM
Scorpi0's Avatar
I wouldnt expect an answer from him. But maybe someone else knows.
jeffbdye
Jun 1, 2018 03:51 PM
KallDay86
Jan 8, 2016 12:42 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
vamarris
Sep 26, 2015 12:56 PM
