What happened to the Motordyne Engineering 3/8" plenum spacers?
Old Jul 27, 2005 | 01:29 AM
Hydrazine's Avatar
Originally Posted by Chico
I have an '05 Sedan RWD Auto. Which spacer do you recommend for my car? I'm a little confused with all the different sizes.
Also, what are the realistic HP gains that I can expect?
Thank You.
You can go with the 5/16" and keep the engine cover on.
Or you can go with the 1/2" without the engine cover.
The spacers perform differently on different cars but generally dyno between 8 HP to 13 HP. The 1/2" spacer will produce approximatly 1.5 HP more than the 5/16".
Old Jul 27, 2005 | 01:32 AM
Hydrazine's Avatar
Originally Posted by dentalstud
But will it work with my 3/8" spacer?
Yes! It will work with the 3/8" spacer no problem. I made special provisions to accomodate the numerous customers with 3/8" plenum spacers.
The Motordyne Iso Thermal plenum spacers are being installed and tested on many cars right now. More details will emerge when the data becomes available.
Old Jul 28, 2005 | 04:36 PM
texasranger2003's Avatar
after a few days with my 3/8 spacer i'm starting to feel the performance difference and i'm sure your new product will be worthwhile as well. Any word on ballpark pricing and performance increases? (hp? torque?, lower mid upper rpm ranges?)
thanks
Old Jul 29, 2005 | 01:04 AM
Hydrazine's Avatar
Thumbs up
The first pre/post dyno to come in was performed a couple days ago on a 350Z in Australia. The 5/16" Motordyne Iso Thermal spacer...
13.4 HP @ 6300
21.8 HP @ 7100.
I don't want to say they will all produce this level of gain but that's what he measured under a controlled dyno. ...And he will redyno again to confirm the numbers.
He is also reporting that his plenum is running much cooler. Here's a small segment of what he wrote.
> Also I would like to update you on the driving experience I had (around
> 15 minutes) after I switched off the coolant valve controller + after
> putting the silicone intake pipe... it was BRILLIANT!!! after a good 15
> minutes of pushing all the way to the 7200rpm redline more than a hand
> full of times, I popped the hood and amazingly that the throttle body +
> intake tube + airbox were not hot at all, just a bit warm only.... I
> couldn't really believe that though... I can basically put my hand or
> even my face on top of those components... I gotta tell you.... this
> definitely helps reducing the intake temperature though!!!
As you can tell, he's pretty happy with it.
It's almost ready for general release!!!
Old Jul 29, 2005 | 01:36 AM
so this spacer would just mount right on top of my 3/8 inch spacer? with similar gains as you described above? if thats the case then thats great.
Old Jul 29, 2005 | 05:13 PM
Hydrazine's Avatar
It won't add that to the gains you are already getting with the spacer. The gains are shown with the spacer and a thermal isolation manager to let your plenum run much cooler.
The Motordyne Iso Thermal plenum spacer and the Motordyne Iso Thermal kit are different packages. The Iso thermal kit is only for thermal management. The Iso Thermal plenum spacer is a plenum spacer kit with the thermal manager added.
Tony
Old Aug 1, 2005 | 01:05 AM
G35 Toronto's Avatar
Tony...just to confirm the new Motordyne Iso Thermal plenum spacer is not officially available (dont see it on your website).
I was just about to ask you about making these things out of phenolic material.... but I did a search first and found this...
I have used phenolic spacers in FI and NA applications and would love to see it on the G35.
very anxious.
Old Aug 1, 2005 | 03:46 PM
headpaneer's Avatar
Cool.
I have your 3/8” spacer but have not installed it yet. I look forward to seeing more info on the kit.
Old Aug 1, 2005 | 04:14 PM
ashadiow's Avatar
What is pricing going to be like?
Old Aug 3, 2005 | 10:33 PM
lexicon's Avatar
anything new?
Old Aug 4, 2005 | 11:38 PM
Hydrazine's Avatar
I havn't updated the price but yes they are shipping at the old price for now...
Old Aug 8, 2005 | 04:52 PM
Keeper92's Avatar
Tony
Hi Tony,
I was just wondering when can we purchase the Motordyne Iso Thermal Kit?
Thanks,
David
Old Aug 8, 2005 | 05:40 PM
Hydrazine's Avatar
HI David,
You can purchase them now even though they are not listed on the web site. When you make the paypal payment, be sure to mention that you want the Motordyne Iso Thermal spacer and I'll put it in.
I will include the extra hardware at no extra cost to you. ...Anyone can purchase them at the current price until the website is updated to show the new Iso Thermal spacers and upgrades.
The website will be updated soon with a new look and with all the new products available.
Old Aug 8, 2005 | 07:07 PM
lexicon's Avatar
Any new updates to the new 5/16" plenum with thermal spacer?
Old Aug 9, 2005 | 11:36 PM
  #30
waiting_R_order's Avatar
HI David,
What exactly is a an Iso Thermal Spacer? Any information appreciated.
