Sedan midpipe by ZcarGarage
Old Jul 19, 2005 | 06:24 PM
MyRedG03.5's Avatar
Question Sedan midpipe by ZcarGarage
Just got off the phone with Rob from Z Car Garage. I was asking about installing a coupe midpipe on my sedan. He said that he makes a custom midpipe for the G35 sedan with a 350Z resonator (~$120). What would be the benefit of this over a normal coupe midpipe(~$100 right?).
Different sound?
Wondering about weigh too as I know the coupe mid is lighter than the standard sedan mid.
Any of you know anyone who has this?
Old Jul 19, 2005 | 06:39 PM
sukhi's Avatar
I Tried this custom midpipe from zcargarage and hated it. It was so raspy. I had him take it off and put the g35 coupe pipe on there. The only difference is that the his was a straight through design with no resonator. I am going to be selling mine in a week or two once i get my new exhaust.
Old Jul 19, 2005 | 06:44 PM
G352NV's Avatar
Never enough
Can someone tell me what part of the coupe exhaust is used? I have two systems. Can I just cut off the mid pipe and sell it or do you need the whole thing?
Old Jul 24, 2005 | 08:09 AM
jran76's Avatar
No need to cut anything. The stock exhaust is in 3 pieces: y-pipe (errr, the part shaped like a Y), the midpipe (this is what sedan owners are replacing, it is the strait pipe that connects the y-pipe to the muffler), and the muffler.
The y-pipe is the same on the G (sedan and coupe) and Z. Each uses a different design, the sedan is very odd looking with a big box that the pipes run in and out of, the coupe is more of a strait through design with a resonator....
Old Jul 25, 2005 | 11:01 AM
townsley's Avatar
I got the 350 mid-pipe from ZCar Garage last year. I think it's great. The 350Z mid-pipe and the coupe mid-pipe are exactly the same. In order to make either fit on a sedan, the aft section needs to be extended by about 6 inches. A common solution to this is to bolt on a short section that extends the pipe.
I don't know whether Rob has something different with this "custom" model, but what I bought from him was a stock 350z mid-pipe with a longer, after section welded on. It was a perfect fit and didn't require any additional secions or bolts - cleaner and lighter in my opinion. The 350Z and coupe have the same mid-pipe, so sound quality/volume is the same.
Personally, I think it sounds great. It's not coupe-like, but it's definitely a bit more aggressive sounding that a stock sedan.
Old Jul 31, 2005 | 06:45 PM
wnpublic's Avatar
I had Rob put on the Z midpipe earlier this year. It's a great mod - and it's no different than the coupe midpipe ('cept it's shorter so it needs an extension). A good thing to do to your sedan whether you pick the coupe or the z pipe.
wn
Old Aug 5, 2005 | 07:32 PM
IQ9's Avatar
IQ9
I got one of the first test sets of Robs midpipe and there is no difference between the coupe or the 350 as Nissan is too cheap to make them different.
jsimonk
Dec 22, 2023 03:49 PM
Jusseth
Sep 13, 2020 12:25 PM
chinee
Aug 8, 2015 10:11 AM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
teamghost
Jul 28, 2015 04:52 PM
