How much burnt oil is too much???
Old Jul 28, 2005 | 12:57 PM
WRAH's Avatar
WRAH
1/2-3/4 of a pint of oil gone/burnt between changes 4000~5000 miles???
I've heard of worse, also, how rich is our mixuture? I'm smelling alot of fuel in the oil?
Old Jul 28, 2005 | 02:08 PM
Q45tech's Avatar
Except when you accelerate the G35 [and all OBD1&2] engines run at or near 14.7AF ratio.
Most oil loss in new engines [under 100,000 miles] comes from the fact that the light components in conventional oil evaporate [up to 20% by volume] in heat and travel up thru valve covers thru pcv system and are feed into plenum where they get burnt with incoming charge.
So 20% [up to a quart] between 90 day/3750 mile changes could be considered normal depending on oil brand and weight. FULL Synthetics being more stable and more uniform should only "vaporize" 5-7%.
Now improper [breakin or positioning] ring set/tension is another situation!
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
