gas smeel during oil change????
Old Sep 22, 2005 | 04:56 PM
QuadCam's Avatar
gas smell during oil change????
I changed my oil last week, and I noticed the very distinct smell of gasoline in the oil. Is this normal on these cars? I am concerned!
Thanks,
Andrew
Old Sep 22, 2005 | 06:22 PM
cato's Avatar
SouthernComfort Moderator
I have changed my oil myself the past two oil changes....never smelled gas.
Sure you didn't fart while under the car? Hehe
Old Sep 28, 2005 | 03:23 AM
socalg35's Avatar
Thanks,
Andrew
I notice it also on my car. I sent a sample to Blackstone for testing. I will let you know what they say. If it is my rings or seals I want to get them replaced before my warranty is up.
Old Sep 28, 2005 | 11:24 PM
QuadCam's Avatar
I assume that Blackstone is some sort of chemical analysis facility. If so, how much and how long does it take to get a sample analyzed?
Thanks,
Andrew
Old Sep 29, 2005 | 05:55 PM
socalg35's Avatar
Got my sample results today. Even though it seemed the smell of gas was strong, it showed that there was less than .5%, it says it should be less than 2%, so my oil is fine.
If you go to www.blackstone-labs.com you can check out the the type of testing they do. First you have to request a couple of sample containers. It costs ~$20-$40, depending on the tests. I paid $30 for the regular test and the additive test (TBN test). It took less than a week for mailing and testing.
derres
Aug 28, 2015 03:27 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
