fuse box missingf hglep
Old Sep 28, 2005 | 09:00 PM
ebuy929's Avatar
hey guy,
i managed some stupid stuff again .
i was changing the leds bulbs in my headlight pipe light and the bulb kept failng out so i took tweaser and tride to tighten the gold clams holdin the bulb to make it stay. next thing i know my stipe light are not working, my corner light are out, my tailights only turn on when i brake, my licence plate wont iluminate, my headlight turning signals only work when i signal not when xenons and fogs are on, and finally my center consol has no lights..
by the way i have a coupe and the light i original tried to install where the little side stripe lights on the side of the headlights. i gues i crossed positive and negative and blew a fuse
i took it to a shop and they couldnt find the correct fuse box to check the fuses they found the one by the battery and under the drivers side . they couldnt find any other fuse boxes for the accesory lights (there was nothing under passenger side)
basicly where is the correct fuse box located.
also what do u think the problem is . a fusE? the mechaninc said its possible i messed up the relay system flasher or somthing and im fuked. ithnk its a fuse
any ideas help suggestion>?
please
Picture Share
Feb 4, 2018 12:41 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
prinny
Nov 22, 2015 11:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
