Where do you hardwire?
Old Oct 4, 2005 | 10:38 AM
MyGUnit's Avatar
For those of you that have hardwired, where do you hardwire to, and how to you get access. I currently hardwired directly to the fusebox, but was wondering if there was a better way.
I hardwired my Sirius receiver (not the Infiniti one, the generic one) and now I'm getting engine noise. I believe its probably from the grounding connection, so where would be the best place to hook this up!?
Thank you in advance.
Old Oct 4, 2005 | 01:01 PM
baileyrx's Avatar
i use the lighter for most switched power source needs
Old Oct 4, 2005 | 02:07 PM
MyGUnit's Avatar
how do you get behind the lighter? to tap into it?
Old Oct 4, 2005 | 11:08 PM
baileyrx's Avatar
remove the shift ****, and lift up the center console. the clips underneath "give" pretty easily.
Old Oct 6, 2005 | 05:52 PM
MyGUnit's Avatar
thats is for the 5at which has the cig lighter in the center console....What about 6mts?
Old Oct 8, 2005 | 07:18 PM
ZeroGen's Avatar
Omega Enthusiast
When you installed the ground wire, did you connect to bare metal? When I hardwired my V1, I grounded to bare metal above the fuse box. I found a screw that tapped into the chassis and grounded there.
Old Oct 9, 2005 | 02:15 PM
SLVRG35's Avatar
Leave it in the fuse box, just change your ground.
Old Oct 9, 2005 | 11:21 PM
MyGUnit's Avatar
Thanks for the replies..I'll have to check out grounding it above the fuse box...
BocaCoupe
Dec 13, 2005 01:32 PM
randygsx
Jun 17, 2005 11:51 AM
kramrd
Apr 26, 2005 07:43 PM
BombRush
Apr 7, 2005 02:32 AM
SagiSRP
Jun 17, 2004 04:32 PM
