300hp engine,stronger? Not really...
When the anniversary motor was released Jason, or one of the crew at Performance Nissan posted pictures on the my350Z site of the new lower plenum, conrod & piston & I am almost certain that it showed the conrod with studs & nuts. I tried to do a search but was unsuccesfull, maybe someone else could try?
Originally Posted by MRC Motorsports
As far as I recall the Nissan 350Z anniversarry in 05 and the G35 6speed shared this high rev motor...
Lou
http://www.my350z.com/forum/showthre...0&page=1&pp=20
We have heard for a while now that the internals on the high rev motor were supposed to be upgraded,but have not yet had the chance to take an 05 motor apart. Well thanks to Jimmy,aka Paranormal,we got our chance. He managed to spin main bearing #6 due to lack of oil. As you can see from the pictures,the rod on the right side is dicolored from the heat and the rod is elongated and egg shaped.A few more seconds and this rod would have snapped and went through the block. Now the rod on the left is out of an 03 model with the 287 hp motor and the rod on the right is from the 05 high rev motor.We can not visually tell the difference in the rods or pistons,so unless Nissan changed the material they used to produce it,the rumor that the 300hp motor is sporting stronger internals is false. We will not make a claim like this without backing it up,that is why I plan on having my engineer take measurments of both rods and give a comparison in the next few days.However upon initial inspections the internals seem to be exactly the same..
MRC MOTORSPORTS
ALL THE FASTEST G'S ARE BUILT AT MRC'S
G35 Driver's OFFICIAL UTEC AND TURBO XS DEALER
UTEC INSIDE
MRC MOTORSPORTS
UTEC INSIDE
Originally Posted by DaveB
#30
Originally Posted by Randys_G
will your measurements include a property test to insure than the material they're made with is same/dif?
