UNORTHODOX RACING PULLEYS, GOOD, OR BAD?
Old Aug 18, 2003 | 10:41 AM
  #31
Tfasano's Avatar
Re: UNORTHODOX RACING PULLEYS, GOOD, OR BAD?
I have a UR pulley, just have not installed it yet. Is it possible to get our answers from someone higher up than our local service center? Maybe someone from development or research or something like that?
Luv My G
Old Aug 18, 2003 | 10:52 AM
  #32
GurgenPB's Avatar
DaveO
What do you mean. Dan you please point out the harmonic dampener? Thanks
Gurgen
2003.0 G35 5AT Sedan
Sport/Winter/Aero
<font color=red>Injen CAI</font color=red>
Eibach Pro Kit
Clear side markers
UR Racing Pulleys - set of 3
Cusco Strut Tower Bar (soon)
Cusco Sway Bars (soon)
Old Aug 18, 2003 | 11:39 AM
  #33
oneshotkill's Avatar
If you are running a high end stereo you will not want pulleys on your car. You will be "underdriving" your alternator and it may not be delivering the voltage and more importantly the current to your amps.
OSK
Save your money. Spend $5K and put a set of heads, new cams, and injectors in your car. Might have to wait a while until they are developed for the car, but at least it will have a real performance enhancement.
Old Aug 18, 2003 | 01:17 PM
  #34
SixFive's Avatar
oneshot - please explain more...how is it underdriven if it's not going any slower?
Old Aug 18, 2003 | 09:20 PM
  #35
Msedanman's Avatar
O.F. Administrator
SixFive, Oneshot was explaining that if you have a high end, high amperage stereo system, you won't want to underdrive your pulleys. This slows them down to a point that may not allow the alternator to deliver enough juice to power your stereo.
A more important issue is whether the stock crank pulley is a harmonic balancer type or not. If it is and you replace it with a non harmonic type, you'll do some long term damage.
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Aug 18, 2003 | 10:20 PM
  #36
DaveO's Avatar
gurgenpb,
Here's another picture of the stock harmonic dampener-pully assembly. This picture was taken from the back (or engine) side of the dampener.
If you look closely you can see the unit is made up of three parts. A center hub, a flexible (hard rubber ?) ring and the outer drive pulley section. The flex ring allows for a slight amount of differential rotational movement between the center hub and outer pulley. That, along with the weight of the assembly, helps to control harmonics caused by the crankshaft's torsional vibration.
DaveO
Old Aug 19, 2003 | 02:19 AM
  #37
GurgenPB's Avatar
DAveO
You are the man! Thanks so mych fo rthe info. This is exactly what I (as well as almost all of us desputing installation of these pulleys) suspected. You have confirmed my fears, although it is all good; I never installed them and am sending them back for an exchange for a set of Cusco Sway bars.
Gurgen
Sport/Winter/Aero
Eibach Pro Kit
Clear side markers
Old Aug 19, 2003 | 08:41 AM
  #38
SixFive's Avatar
Yeah these pulleys seem like possible problems for a couple HP. The flywheel idea seems better but expensive - I saw 800 bucks...I bet it drives great though. Any potential probs with a lightweight flywheel guys and gals? I want a ECU upgrade dammit.
Old Aug 19, 2003 | 09:31 AM
  #39
malx's Avatar
So what's the ruling? Good? Bad? Someone list EXACTLY what one would need to get the pulleys working. If you need belts, etc. Also, anyone in for a group buy? Once I get all of the info I will try to set one up. For those of you who had the dealer install the pulleys, how much did it cost you?
Thanks - Joey Avino
Old Aug 19, 2003 | 12:02 PM
  #40
GurgenPB's Avatar
Cool
SizFive, the ecu upgrade is coming in the next several weeks for the sedan (if that's what you have). I am the test sedan for them (technoSquare)
GUrgen
Sport/Winter/Aero
Eibach Pro Kit
Clear side markers
Old Aug 19, 2003 | 12:03 PM
  #41
GurgenPB's Avatar
Malx
It is definitely BAD. Just too much trouble for 5 horsies.
Gurgen
Sport/Winter/Aero
Eibach Pro Kit
Clear side markers
Old Aug 19, 2003 | 12:30 PM
  #42
malx's Avatar
How is it too much trouble?
Thanks - Joey Avino
Old Aug 19, 2003 | 01:09 PM
  #43
humanRESEARCH's Avatar
SixFive, the lightweight flywheel (JUN is the one I'm going with- I don't care for the Jim Wolf flywheel) shouldn't present any problems...Some people think that lightweight means fragile, but with JUN's manufacturing and today's materials it should be incredibly durable and reliable...Nissan products lose so much horsepower to the wheels because of the fact that they use such heavy flywheels, but in their defense they do it to be durable...
As far as the UR kit, probably not a good idea...Good exchange I think, the UR for the Cusco bars...
"All the Power in the World resides in the Eyes..."
Old Aug 20, 2003 | 01:49 AM
  #45
IS300TOG35's Avatar
► Matt ◄
what kind of power would be expected with a jun flywheel?
