05 Lower collector install on 03/04 VQ
Old Dec 20, 2005 | 11:07 PM
KAHBOOM's Avatar
Exclamation 05 Lower collector install on 03/04 VQ
OK so I was reading in sport Z mag about an install of a lower collector from a Revup engine into an 04 Z. There were gains accross the board as high as 10 WRHP at peak and 10 WRHP at 2K RPM (anywhere from 5 to 9 in between)
The part was $297.00 and can be obtained from your Infiniti or Nissan parts department.
So am I understanding correctly that I can buy a lower collector for an 05, install it in my 03 and get some benefit?
Any other thoughts???
Old Dec 20, 2005 | 11:11 PM
godmans's Avatar
you sure???
gain across the band??
since the 05+ REVUP lower collector design is to boost high end horses with the sacrfice of mid range torque and power (by most dyno plots we have been seeing..)
I would love to see this.. since i have a 04 motor..
godmans
Old Dec 20, 2005 | 11:12 PM
KAHBOOM's Avatar
If I am reading this correctly the dyno numbers that they posted indicate the above- certainly an interesting read that caught my attention.
Old Dec 20, 2005 | 11:19 PM
godmans's Avatar
Question
maybe we can wait for Tony from Motordyne to give some suggestions for this one..
do you think if it is possible for you to scan the particular dyno plot? or the paragraph? i am really really curious!
Old Dec 20, 2005 | 11:21 PM
KAHBOOM's Avatar
I don't have access to a scanner...Mine pooped out sorry. I am sure Tony could confirm the results however.
Old Dec 21, 2005 | 12:31 AM
trey.hutcheson's Avatar
It's my understanding that the results they saw happened to be for one particular z. I don't believe they were able to reproduce the results again.
Could be wrong though.
Old Dec 21, 2005 | 01:19 AM
GEE PASTA's Avatar
Florida G35 Club
If IM correct, I believe this dyno pull on this Z did make more upper end power.
I know there has been some other dyno runs made on this setup that didn't show very good.
The thing I remember the most about that day is all 4 cars went home running much better.
Now as for Ed's Z His first dyno run had some Pinging and just needed the carbon blown out of it. Again, I remember telling Ed how much better his car sounded after a few pulls. It was a very busy day and doing all the changes on each car took time. My personal opinion is I do not belive the Hi-rev lower plenum to be a good install for the non" rev-up engines. the one thing the magazine can't give you is the sound the VQ'S make at 7200rpms on
a dyno. Sweet music.
Old Dec 21, 2005 | 03:43 AM
xswl0931's Avatar
The chart in the mag clearly shows significant gains particularly in the lower end with just the 05 lower plenum installed. If they are saying this isn't typical, then they should have done more tests rather than publishing the numbers as people may now be installing the lower plenum expecting similar gains.
Old Dec 21, 2005 | 07:55 AM
KAHBOOM's Avatar
Yeah I would certainly like to see more tests done...
Here is a question: Is there any difference in the Revup and the standard lower collectors in shape or portal size?
Old Dec 21, 2005 | 12:11 PM
DaveB's Avatar
Shorter runners and less power until 6,300rpms. All your questions are answered here:
http://www.350zmotoring.com/forums/s...ad.php?t=23423
Alex Koss
Oct 29, 2021 12:53 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
mann1961
Aug 9, 2015 08:44 AM
