Drip Noise After Turning Off Engine
Old Jan 10, 2006 | 10:05 PM
gnight's Avatar
I have a new G35 with 1300 miles. When I turn off the engine I hear what sounds like a drip and the engine emits a strong smell. I was told by the dealer that the smell is normal for new engines and should go away after a few hundred miles. Well, it is now over a thousand miles and the smell has not gone away. I looked to see if anything was dripping under the car and could not find anything, and I have not been using the AC to cause a condensation drip. Is this normal?
Old Jan 10, 2006 | 11:06 PM
G35Five_O's Avatar
Sound like the oil dripping back down into the pan. If so, then that is normal.
Old Jan 10, 2006 | 11:10 PM
wanalaugh74's Avatar
Mioght be the exhaust cooling down too.
Old Jan 10, 2006 | 11:21 PM
Andy2434's Avatar
+1 . . . Yes, it is most likely the heated exhaust components contracting and thus . . . Making the sound, which you are hearing.
Old Jan 11, 2006 | 01:53 AM
636Racer's Avatar
wouldnt that make a ticking noise?
I think I'm having the same noise he's having...I think it's the fuel pump shutting off - sounds more like a faint sqeaking noise. If you turn on the ignition, not cranking the engine over, and switching the ignition back off..I'd get that noise.
mtlruss
Dec 20, 2015 01:51 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
