Natural Aspiration mods
Old Jan 16, 2006 | 02:40 AM
cloud's Avatar
I have tried to searched the forum for NA mods but since the term Natural Aspiration is always abbreviated as NA, the search engine isn't too useful.
I've been thinking of NA mods recently(damn mod bug) and would like to know what mods are the best for NA.
Please list them with the reliability(voiding warranty / possibility of causing problems) and gains.
Old Jan 16, 2006 | 11:42 AM
MikeStarrG35's Avatar
Obsessive Owner
1. Motordyne Engineering MREV - most respectable NA gains, best bang for the buck, easy install, 100% reliable.
2. Z-tube - gains are negligable, but it greatly improves the induction noise, especially at WOT
3. Air Intake - something to replace the stock intake. There are endless debates about which ones are better, search it. I have the K&N filter, and love it. I just purchased an Amsoil filter to change things up a bit. If you want my K&N its your for $40 (has 200 miles on it)
4. Headers - I have some sitting in the garage but have not installed yet. Supposedly should give respectable gains (search for numbers). Costly mod though, and extremely costly install
5. High Flow Cats - also sitting in my garage waiting for install. These will help amplify all the above breathing mods. About $500, with 1-2 hour install.
This should get ya started, good luck and happy modding.
Old Jan 16, 2006 | 03:44 PM
G-Tofu's Avatar
Air Intake + Plenum + high flow cats................NOTHING ELSE will give you true gain
Old Jan 17, 2006 | 12:37 AM
cloud's Avatar
New to mods
I have the MREV plus already but not installed yet.
but what exactly are high flow cats?
Old Jan 17, 2006 | 02:07 AM
deadmanincbh's Avatar
I haven't visited this site for a while but what is Motordyne Engineering MREV? Is that a certain model of an intake plenium?
Old Jan 20, 2006 | 04:43 PM
g35rcr's Avatar
high flow catalytic converters allow the car to expel more exhaust gas vs the stock cats...the gains are marginal, mostly for sound
Old Jan 20, 2006 | 09:44 PM
godmans's Avatar
some people had some really good experiences with test pipes =)
search for it
Old Jan 24, 2006 | 12:47 PM
ekwc's Avatar
Pulleys
Old Jan 24, 2006 | 03:50 PM
RashMan1450's Avatar
yea dont forget about a crank pulley. Also look into a catback exhaust. You will get like 3-6 hp to the wheel from that.
Old Jan 24, 2006 | 05:02 PM
Rickdogg's Avatar
"My picks for basic NA bolt-ons without going internal:
Intakes: Stillen, Gruppe-M, ARC for high end power or Cold Air units for mid-range power. Stay away from short ram intakes that are not enclosed.
Headers: Crawfords if you want to extract max power. Strup, DC, etc if you want cheap hp and only looking for bang for buck.
Cats: Crawford High flow cats or Test pipes
Engine Management: Technosquare reflash, Utec for those in high altitude, or Full standalone Motec for full tuning
Throttle Body: 350evo, proflow, crawford
Plenum Mods: Motordyne 5/16" spacer with Iso thermal system for 287 HP motor and MREV mod for Revup motor, or Crawford Cast plenum
Exhaust: JIC single exit ti for max weight savings, Power Amuse Ti
Gears: 350evo 3.917, Central 20 3.917
LSD: Nismo, Quaife, Kaaz, etc
Underdrive: UR Crank Pulley
Cooling: Koyo Radiator, Motordyne Coolant Control Valve or Motordyne Copper thing."
Old Jan 25, 2006 | 06:19 AM
cloud's Avatar
I'm abit confused with these, I did a search and yes there are alot of reviews but none of them really helped clearing the terms up.
So, Test pipes , Y pipes and high flow cats go in the same place? Whats the difference between them?
Also, I've read that with a true dual exhaust, you won't need the cats/pipes? Whats the difference between the true dual exhaust and the normal ones?
Old Jan 25, 2006 | 10:01 AM
wnt1bd's Avatar
OK, Test pipes replace the Cats"catalytic converter" High flow cats replace stock cats, test and high flow are 2 seperate parts that can not be combined. The "Y" pipe is right after the cats and what it does is takes the exhaust gases from the cats and puts that to a single pipe that runs to the muffler. There are other alternatives to that as weel, such as "h" pipes and true dual exhausts.
Old Jan 25, 2006 | 10:47 AM
FenixL1P's Avatar
don't forget the NISMO sticker across your windshield for an added 15hp.....sorry just had to point it out...
e420x's Avatar
Mod Junky!
Full exhaust with Y-pipe should add a solid 10-15 depending on what you go with
Old Jan 25, 2006 | 11:00 AM
Rookie84's Avatar
I'm planning to do:
MD 3/8" spacer(have been sitting in my garage for quite some time...)
MD Iso Thermal upgrade
K&N Filter
Z-tube(maybe)
Strup headers
Test pipes
Y-pipe + exhuast or dual exhaust
UTEC & tuning
I think that covers just about everything and will give me the most power for NA setup without touching the engine.
