Need advice...problem screw broke.
Old Jan 31, 2006 | 12:15 AM
ZLUJ's Avatar
Mmhm...
I was installing my 1/2 plenum spacer with ISO thermal gasket...when i was putting the lower plenum back together, and i guess there was a malfuntion in the torque wrench i bought and it ended up torqeing my intake maknifold collector screw too much and cracked it, i was wondering is it safe to put my engine back together until i get the screw or should i just wait and not risk having one screw not in?
Old Jan 31, 2006 | 12:21 AM
Andy2434's Avatar
Ouch! Hmmm . . . That's 1 of 6 bolts, which bolts down the lower collector directly to the intake manifold. If it were me, I'd wait til I got a replacement bolt and avoid a potential problem. Good luck!
Btw . . . Just to be sure, you used an inch-lb. torque wrench with a final setting of 100 inch-lb., right?
Old Jan 31, 2006 | 12:30 AM
ZLUJ's Avatar
Mmhm...
yes i used an 1ch lb torque wrench...somethign was wrong with the wrench, it wasnt it was a cheap one that has like a needle type of deal and the needle moves accordingly to how much the bolt is torqued.. the hell wiht that one.. i just bough another one.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
jbmw002
Sep 10, 2015 12:54 AM
