Please help with electric radiator fan info.
Most everyone know's the Auto Trans Sedan's are burdened with an engine driven radiator fan. This 16.5" diameter clutched "puller" fan has 7, 5" long blades. A second motor driven 12"-14" "pusher" fan is mounted between the grill and radiator in front of the intake air box. Together, both fans essentially cover the radiator's core.
I'd like to get the basic specs and (if possible) pictures of the electric fan setup from a G35 MT Sedan or any Coupe.
Info needed;
Number of fans - ?
Type of fans (puller, pusher, one of each) -
Diameter of fans -
Blade length -
Number of blades -
Thanks in advance!
Info needed;
Number of fans - ?
Diameter of fans -
Blade length -
Number of blades -
Thanks in advance!
Re: Please help with electric radiator fan info.
Hey dude, My Coupe has 2 puller fans that are 14" in daimeter with 5- 5" blades in them. They are mounted in one famework between the radiator and the engine and cover most of the radiator. Good luck with your mods.
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Thanks GSM,
Any chance of a picture or two?
I'm considering a single 12" Flex-a-Lite puller fan with either their standard temperature sensor and A/C relay or their new VSC (Variable Speed Control) unit.
DaveO
<P ID="edit"><FONT class="small"><EM>Edited by DaveO on 08/24/03 08:04 PM.</EM></FONT></P>
DaveO
This is about as good as it gets in there bro without taking things apart, sorry:
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>92651-engine fans.jpg
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
FS[NorEast]: New OEM G35x Compression Rods - Save!!
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Learned Hand
Oct 1, 2015 09:02 AM
