Checking and Refilling Oil
Old Mar 23, 2006 | 11:53 PM
Dan_K's Avatar
Just checked my oil with the dipstick today for the first time and I'm not sure how much to put it in. The oil is at 25% between the Low and High Meter, so I am thinking half a quart?
I usually get an oil change every 3 months @ around 3000-4000 miles and refill it with Mobil 1 Synthetic. But, it's been about 5 months and I've only driven it 2k miles, so I would just like to top it off as the oil isn't that dirty.
Old Mar 24, 2006 | 12:21 AM
blksnake's Avatar
Taken from the Maintenance section of the service manual:
7. Warm up engine and check area around drain plug and oil filter for oil leakage.
8. Stop engine and wait for 10 minutes.
9. Check the engine oil level.
Old Mar 24, 2006 | 12:58 AM
Dan_K's Avatar
Normally, how much oil does it take for it to go from 25% dipstick level to at least 75%?
Old Mar 24, 2006 | 03:08 AM
Goods's Avatar
You know, there's an easy solution to your dilemma.
Old Mar 24, 2006 | 03:48 AM
limeg35's Avatar
ummmm...buy a new car?
Old Mar 29, 2006 | 06:52 PM
bythabay's Avatar
The area between min and max on the dipstick represents one quart of oil. so if it is at 25% and you pour in 75% of a quart, you will be at max on your dipstick. And I emphasize that you wait at least 10 minutes before checking the oil to get an accurate reading. Also make sure you are on a very level surface..
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
2_Liter_Turbo
Jan 19, 2018 01:48 AM
joedaddy1
Jul 28, 2015 02:58 PM
ClwMike
Jul 23, 2015 12:55 PM
