MD 5/16" spacer torqued center 6bolts with 100 in-lbs
Old Mar 27, 2006 | 12:35 AM
harmless52's Avatar
Red face MD 5/16" spacer torqued center 6bolts with 100 in-lbs
hi guys.
Finaly I installed my MD 5/16" spacer on my car today.
everything was fine, but There was one problem with 6 center bolts.
I did the test drive after the installation. and I checked 6 center bolts(because someone had a problem with 6 center bolts.) after test drive, doesn't stay torqued with 60 in-lbs. So I re-torqued with 100 in-lbs 6 center bolts. would be ok with 100 in-lbs?
Old Mar 27, 2006 | 12:47 AM
Andy2434's Avatar
I had to retorqued the said center bolts 4 times to 60 inch-lbs. until they all held. This was over a period of some 3 months, as I checked from time to time. I would not torque the center bolts much more than you have. Wait a week and see if they hold at 60 inch-lbs. I think they will.
Old Mar 27, 2006 | 01:40 AM
harmless52's Avatar
Thank you andy.
But I already re-torqued 100 in-lbs........ Is it okay? What I worried is inside of plaum 6 plastic internal supports(I wish it stay ok. ;(
And I won't torque 100 in-lbs anymore as you said.
Old Mar 27, 2006 | 01:52 AM
Andy2434's Avatar
You should be fine. I would have initially been a bit more concerned about breaking a bolt ot two. Some members have reported snapping bolts, due to over torquing. However, it appears that you survived that peril.
I would simply sit back and enjoy your handy work and check the bolts at 60 inch-lbs. in about a weeks time. Enjoy your new spacer.
Old Mar 27, 2006 | 03:09 AM
99atlantic's Avatar
you knwo what's weird; i know a lot of paper say their center bolts become untorqued over time, but i checked them again for the 2nd time in 3months (since i had plenum stuff installed) and mine havn't budged at all.....weird?
Old Mar 27, 2006 | 03:15 AM
harmless52's Avatar
sup atlantic~
Give me your plenum and spacer... LoL
Old Mar 27, 2006 | 07:57 PM
thx007's Avatar
Exclamation
Noooo, 100 in/lbs is too much for the center bolts! Read this thread, especially from Hydrozine which is Tony of Motordyne Engineering.
https://g35driver.com/forums/showthr...t=84880&page=2
Center bolts shouldn't go over 75 in/lbs...
Old Mar 28, 2006 | 11:11 AM
DaveB's Avatar
I think Hydrazine is right in that the plastic spacers heat cycle and after a while they stop cycling which allows you to get the bolts perfectly torqued. Mine are still at 75 in/lbs and holding fine. At first I was using 60 in/lbs and having to retorque every couple of days. I kicked up the torque a bit and everything was fine.
Old Mar 28, 2006 | 12:50 PM
G35_TX's Avatar
Originally Posted by harmless52
hi guys.
I personally think 100 is a bit to much. 70-80 would have been fine.
Old Mar 28, 2006 | 02:26 PM
GT-Ron's Avatar
Would Locktite hold those center bolts and keep them torqued while the plastic spacers heat cycle?
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
StreetStandard
Accessories-Vendor
67
Aug 15, 2016 02:45 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
