Spacer: 5/16 vs. 1/2, Which to choose?
Old Mar 29, 2006 | 05:37 PM
3 DOWN's Avatar
Which is better and why? The 1/2 seems like it makes more power, but it seems like the 5/16 is more popular, is there a particular reason?
Old Mar 29, 2006 | 05:58 PM
absolutg's Avatar
workin...
1/2" doesn't let you keep the engine cover so lots of ppl opt for the 5/16. power is pretty comparable, u might gain 1-2hp with 1/2"
Old Mar 29, 2006 | 06:07 PM
ballisticus's Avatar
I have the 1/2" because I dont like the engine cover anyway. Seems like it would trap heat under there. Just paint the plenum and the spacer edge and it will look fine.
Old Mar 29, 2006 | 06:12 PM
scorcher76's Avatar
Engine cover...
If you opt for the 1/2" and remove the engine cover, wouldn't that make you hear more engine noise...kinda annoying one might think...
Scorcher
Old Mar 29, 2006 | 06:17 PM
I have the stillen exhaust with test pipes. I cant hear my engine Actually, just kidding. No difference in underhood noise that I could tell. 99%sure the cover is just cosmetic. The VQ valvetrain is pretty quiet.
Old Mar 29, 2006 | 08:06 PM
papagz's Avatar
im going with the 5/16th ill keep the engine cover and take the 1-2 hp loss
Old Mar 29, 2006 | 08:31 PM
Andy2434's Avatar
Scorcher
I have removed my engine cover since installing the spacer. I have not noticed any increase in engine noise that the cover might have insulated.
Old Mar 30, 2006 | 01:17 PM
3 DOWN's Avatar
has anyone driven the 2 and felt any difference? are the dyno #'s that different between the two?
Old Mar 30, 2006 | 02:04 PM
jimmykce1's Avatar
I think I read somewhere on this forum that the 5/16 spacer makes better power over all the power bands than the 1/2 spacer. However the 1/2 spacer gets a little more power in the upper power ranges.
When I am ready to buy, I will be getting the 5/16 spacer.
Old Mar 30, 2006 | 04:17 PM
Zat_Zuma's Avatar
The question is statement true for just the 300HP or the 287HP?
The 300HP MREV + kit works the best with a 5/16" spacer for midrange torque and loses a few horsepower in the upper RPM range.
However I'm not sure if that a 5/16" plenum spacer works the same way on a earlier 287HP engine. It may be the 1/2" spacer gives the best performance
Anyone care to jump in and set it straight?
Old Mar 30, 2006 | 05:13 PM
3 DOWN's Avatar
Oh BTW my car is an 04..
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
