mrev for 2004?
Old May 17, 2006 | 11:12 PM
wan2hmp247's Avatar
mrev for 2004?
hi i know there was a thread on the mrev for 2004 engines but can anyone just list what i need to get for the best performance? because i am still not sure what mrev does lol i really dont know what the plenum does. so what would i need to buy from motordyne for my 2004 6mt coupe
Old May 18, 2006 | 12:55 AM
GLuXuRy's Avatar
1. the mrev allows better air flow in the motor
2. the plenum directs air into the motor. Plenum aka intake manifold
with mrev... it is designed to allow better air flow into the motor.. more air + more fuel = more power
Old May 18, 2006 | 01:37 AM
wan2hmp247's Avatar
oh ok thanks so which unit do i need to buy for the 2004 version?
Old May 21, 2006 | 04:18 PM
OCG35's Avatar
as far as lower collector (MREV-2) - it is still being determined... still new and not that many dyno tests (or even butt dyno reports)... I can tell you first hand however the 1/2" spacer and IsoTherm kit is a performance benefit. I've had great results as well as many others. Reviews are in abundance throughout these threads.
Old May 21, 2006 | 05:56 PM
wan2hmp247's Avatar
shoudl i go with a crawfordz plenum? or get the 1/2 iso therm spacer? i dont really care about the engine cover fitting or not i just want the one that will yield most power. im also still waiting to hear about the mrev2
Old May 21, 2006 | 09:05 PM
OCGsedan's Avatar
to add to that Q: would it be better to wait for all the MREV testing to be completed before buying anything so as to:
1) optimize (figure out) zactly what u need to buy
2) do an install all at once Vs going in multiple times?
Old May 21, 2006 | 10:26 PM
OCG35's Avatar
Crawford plenum gets great reviews (as does the spacer)... performance-wise it's a toss up... if you want a stealth/OEM look go with the spacer, if you want to show off an after market mod get the Crawford... the spacer is quite a bit cheaper too. Both are fine products, I'm partial to Motordyne, but you can’t go wrong with either.
Old May 21, 2006 | 10:31 PM
OCG35's Avatar
It's a personal choice, but I would. I have 1/2" spacer and Iso-Therm kit and have been very pleased... I am considering the lower collector but waiting for more result testing.
If you are stock it sounds like the new MREV-2 is getting good results with 5/16" or possibly by itself... RevUp G's have posted great things about the original MREV... depends on how you do things... I'm the kind of person that tries to get as much info as possibly before making a decision - there just isn’t that much info out there yet about the 2nd gen MREV.
Just my .02
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
alinero718
Sep 27, 2015 09:35 PM
