Plenum vs. spacer
Old May 19, 2006 | 01:12 PM
Stallion's Avatar
Plenum vs. spacer
What's the difference between buynig a plenum or a spacer besides $50?? I don't see the difference and would rather have a new plenum for looks then the stocker with the spacer. Thoughts?
Old May 19, 2006 | 02:18 PM
G35SanDiego's Avatar
If your referring to the MREV lower plenum then you will not be seeing it once it is installed, the spacer is actually more visilbe. If you are refering to an upper plenum then yes you it is a visual upgrade as well as a performance.
I suggest visiting motordynengineering.com and see for yourself, as well as doing a quick search as to which is more popular for what reasons. In either case you can't go wrong.
Old May 19, 2006 | 02:29 PM
vengeqi's Avatar
if you're planning other upgrades in the future, like a new exhaust, it's better to go with the new plenum (i think a lot of people recommend crawford, but kinetix is an option too).
the spacer keeps the stock look somewhat (because the oem engine cover fits -- at least when it's 5/16), which comes in handy if you have to bring it into the dealer to get something warranty-related fixed.
i think you have to cut the cover or get a new cover if you get a new plenum. (if you *want* a cover, that is...)
performance gain is probably about the same for both...maybe marginally better for a new plenum?
Old May 20, 2006 | 12:35 AM
EricIsKlumzyee's Avatar
less more area = more "stored ready to use air" = better throttle response and top end..
whats the difference between plenum & plenum spacers vs manifolds (mrev).. spacers increase area... manifolds modifies the runners.
Old May 22, 2006 | 01:28 PM
Stallion's Avatar
kintex plenums look like they have an area to fit in the sways for the z. Wouldn't this sacrifice the volume gained by replacing the plenum. Afterall, the reason to replace the stock was to increase the volume.
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
