FS[MidWest]: OEM EXHAUST (HR Y, DE Y, 350z MID, COUPE MID)
Old Mar 8, 2013 | 01:34 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
I need to make some space in my garage, and these items will need to go. Keep in mind I am in Western Colorado, Shipping will be covered by the buyer. If you are local to Colorado, I can arrange to meet somewhere halfway.
*****SOLD***** First item: This is an OEM 2008 350z HR Y-Pipe, its the real deal not the smaller G35(HR), G37/370z Y-Pipe that people try to pass off as this one. The inlets are 2" and the outlet is 2.5". It matches up perfect to the OEM mid, it was designed to maximize performance using OEM sized piping. With approximately 60k Miles, the heat shield has a bend on it and the passenger flex joint has some frays, there are no leaks, bends or kinks to the actual Pipe, It will need a new stud on the collector end. Im asking $80 + Ship & PayPal.
Second item: OEM 2006 G35(RWD) DE Y-Pipe, it has been sitting in my storage unit since I took it off. It was used for approximately 45k miles. The inlets are 1.85" and the outlet is 2.25". I will take no less than $50 + Ship & PayPal.
INLET
OUTLET
*****SOLD***** Third item: CURRENTLY ON THE CAR, an extended OEM 2003 350z Mid-Pipe, again this is an already extended Mid-Pipe which makes it a Coupe Mid-Pipe. The extension is welded on, you can remove it to fit your 350z. The inlet is 2.5" and outlet is 2.5", it frees up flow by using a calsonic resonator instead of a chambered resonator like the sedans use. On top of better flow, there's the added growl that gives it a similar note to the Coupe/FX/Z. Again no less than $50 + Ship & PayPal.
Fourth item: ONE extension that I used on my NOW extended 350z Middy, it will bolt up after the Y before the Mid-Pipe. It is 2.25" inlet and 2.25" outlet, you will need to grind the flange bolt holes a bit to get the studs through, in this case you will only need one extension. $20 each + Ship & PayPal.
Fifth item: This is a flex joint that came off a MEGAN HR Y-Pipe, the other one got shredded and I welded straight pipes on it. this is in good working condition, no leaks, but some serious frays on the outer flex shield. these usually sell for $40 new, will gladly take $10 + Ship & PayPal.
Sixth Item: OEM 2006 Sedan Muffler, has approximately 90,xxx Miles on it. $75 + Ship & PayPal.
File Type: jpg
Old Mar 11, 2013 | 05:55 PM
tylawg35's Avatar
how much for the HR Y pipe shipped to 92020? ill take it
Old Mar 12, 2013 | 12:48 PM
G3531's Avatar
Seconds on the Y if that falls through for any reason
Old Mar 12, 2013 | 07:13 PM
re-crue13's Avatar
HR Y is pending payment.
Old Mar 13, 2013 | 06:41 PM
jos03g35's Avatar
how much for the mid pipe shiped to 98274
Old Mar 13, 2013 | 07:01 PM
re-crue13's Avatar
I will check tomorrow morning, stuck at work all nite
Old Mar 13, 2013 | 07:28 PM
jos03g35's Avatar
ok thanks
Old Mar 15, 2013 | 04:51 PM
yoyoyo8's Avatar
HR Y PIPE still available?
Old Mar 15, 2013 | 04:52 PM
re-crue13's Avatar
HR Y is still available, pending payment if by the end of tonight he doesn't PM, I will move on to the next person.
Old Mar 18, 2013 | 10:42 AM
re-crue13's Avatar
HR Y Pipe Sold, Coupe Middy Sold.
Old Mar 19, 2013 | 06:37 AM
fairladyz13's Avatar
If anybody missed out of jherns HR y pipe I have one in perfect condition I'm about to sell, not trying to thread jack just don't have enough posts to make a fs thread.
Old Mar 20, 2013 | 12:33 PM
AZWoodG35S's Avatar
I need one of the y pipe extensions. Pm me with the paypal info. I live in az area code 85013. Thank you
Old Apr 24, 2013 | 04:33 PM
re-crue13's Avatar
Bump
R350k5
Oct 1, 2015 08:41 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
LoSt180
Jul 15, 2015 08:31 AM
