Unbelieveable Forged/Carbonetics Twin Disc Clutch Special!!! -->>>>LOOK!
Forged Performance and Carbonetics have teamed up to give you guys a limited time steal on these clutches! You will never find a better price or a better deal on these clutches...PERIOD. This deal will only last until the end of 08'! After the end of the year you will not be able to get these clutches at this rediculously low price! Dont miss out on your chance to get this clutch at this one time low price! Carbonetic got stuck with a few extra twin disc clutches, so they are looking to the #1 350Z/G35 dealer in the country to move this stuff out....and FAST!
ACN23280-11
Twin plate clutch for 350Z up to 450whp
Total weight 37lb
Flywheel 21.8lb
This clutch setup is best suited for normally aspirated cars, or mild forced induction up to about 450whp-500whp depending on the dyno. This clutch has a sweet engagement which allows for a smooth and quick shift. Carbonetic clutches also last nearly forever. We have been using the same Carbon Clutch on our Time Attack race car for over 3 years!!! Still working perfectly on the track.
MSRP $2399
$1490 Shipped!!!
ACN23280L-11
Twin plate clutch with right weight flywheel for 350Z up to 450whp
Total weight 25.6lb.
Flywheel 9.9lb
This is good for street and heavy track use including Time Attack. This option includes a lightweight flywheel allowing REVs to pick up faster. This also has a sweet engagement with creates a smooth and quick shift. This clutch also has a high heat resistance. This option is designed for the more serious track warrior.
MSRP $2399
$1490 Shipped!!!
Both setups have the capability to upgrade to a higher pressure plate and triple carbon clutch. So down the road, the twin disc is upgradable to triple disc, should power needs require that.
Both Kits can be upgraded to a Triple for $800!
Both kits include the following:
forged aluminum cover
two carbon/carbon composite friction disks.
one carbon coated steel flower plate.
light weight Chro-moly flywheel.
clutch bearing and sleeve.
ACN23280-11
Total weight 37lb
Flywheel 21.8lb
MSRP $2399
$1490 Shipped!!!
ACN23280L-11
Flywheel 9.9lb
MSRP $2399
$1490 Shipped!!!
This is a limited time offer, get them while they are available at this price!
I have one of these two that was purchased from Sharif. I didn't know there were more than one. Is there any way to find out which one I have? My name is Tim Trank and it was purchased earlier this year.
