Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Z1 Silicone Hoses... PCV, Heater, Coolant and more!!!
Old Jun 12, 2011 | 11:15 PM
Z1Motorsports's Avatar
We have an entire product line of replacement silicone hoses for the Z33 platform in stock, ready to ship with three colors to choose from. Below is a sampling of what we have in stock and ready to replace your aging rubber hoses.
PCV System Hoses
Silicone PCV Hose Set
Silicone Crankcase Ventilation hose (Front Crossover)
PCV Hose 2
PCV Hose 3
The links will take you to detailed listings showing the exact location of each hose on the engine.
Coolant / Heater System Hoses
Heater Core Hoses
Oil Filter Block Coolant Line (U Shaped)
Oil Filter Coolant Line (Long)
Oil Filter Block Coolant Line (Short)
Coolant Bypass Hose
Power Steering System Hoses
Power Steering Cooler Supply Hose
Power Steering Pump Supply Hose
Brake Booster Vaccum Hoses
Brake Booster Hose Set
Brake Booster Hose, Booster Side Only
Brake Booster Hose, Engine Side Only
We also have an all-in-one Silicone Master Hose Set which includes 17 hoses for your engine bay.
Note: Some hoses not applicable to HR engines.
For a full listing of universal and custom fitted silicone hoses and couplers click Here.
All Z1 Silicone hoses are 4 ply material and designed to outlast the life of the car. Any hoses that carry oil or petroleum based fluids are made from a special flourosilicone material that is resistant to oil and the effects it can cause on standard silicone hoses. All hoses come in Red, Blue, and Black.
It's makes no sense to buy OEM rubber hoses when longer lasting silicone replacements can be had for the same or less money.
Old Jun 12, 2011 | 11:25 PM
SxExCx's Avatar
Bravo! This is the first offering of this kind I have seen! I see success in your future with these!
Old Jun 12, 2011 | 11:31 PM
G35Papa's Avatar
Impressive. +1 these should be a hot item
Edit - I just checked your pricing for the master kit....thats a great deal!
Old Jun 13, 2011 | 12:49 AM
CandlestickPark's Avatar
ill Sedan
Wow, very cool! And great pricing too. You should sell a lot of these.
Old Jun 13, 2011 | 12:57 AM
SDGenius's Avatar
Wow, sweet deals...
Old Jun 20, 2011 | 12:05 AM
Thanks for all the compliments. These silicone hoses are designed to outlast the life of the car. No more cracked rubber hoses causing vacuum or boost leaks.
Old Jun 27, 2011 | 12:35 AM
In stock and ready to ship.
Old Jun 27, 2011 | 01:09 AM
SxExCx's Avatar
do the brake booster hoses have built-in check valves like the OEM?
Old Jun 29, 2011 | 07:04 PM
AreSicks's Avatar
Do you all carry the hose I circled in this picture? It goes from the upper radiator pipe to the drivers side block. Theres another short hose right below it too. Looking for those two if you carry them.
Old Jun 29, 2011 | 11:10 PM
greatyoupeople's Avatar
hoses
are these hoses thicker in size than the stock ones? Just curious
Old Jul 7, 2011 | 06:54 PM
They are slightly thicker than OEM.
Old Jul 13, 2011 | 04:02 PM
Hoses are in stock and ready to ship.
Old Jul 13, 2011 | 04:26 PM
SDGenius's Avatar
do you have hoses that could be used for oil catch cans?
Old Jul 25, 2011 | 05:48 PM
Hoses in stock, ready to ship.
Old Jul 25, 2011 | 05:49 PM
We have multiple sizes of silicone hose in any length you need. They can be found here.
