Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Lighten your G with a Z1 1pc Aluminum Driveshaft, Crank pulley and Idler Delete!!!
Old Jun 1, 2012 | 02:55 PM
Z1Motorsports's Avatar
Bump!
Old Jun 1, 2012 | 03:05 PM
Footballmania32's Avatar
Driveshaft shipped to 78023 for a 03 coupe 5AT. Thanks!
Old Jun 4, 2012 | 10:46 AM
mpugeda's Avatar
My review of Z1's DS (MT):
Blue (before) = 269.6HP
Red (after) = 282.2HP
Blue is with stock DS and an r2c intake
took the car down, installed z1 DS and stock rev up airbox (someone at hill's took at interest in the r2c so I gave him a good price on it). strapped car back down and Frank did a quick touch-up tune
red is with z1 DS and my stock rev up airbox
Temps. about 68-70F
Impressions:
-Certainly feels lighter overall, can't really describe it but the difference is noticeable when punching it
-Acceleration is smooth
-Feels like it climbs through the RPM's quicker
-Definitely a slight "hollow-ey" noise in 1st gear with windows down and like others, it doesn't bother me at all
-Feels "torquier" down low
-Found an open stretch on I-95 so I took it up to 120mph with the intentions of noting any vibrations and felt none. Feels just as smooth as it did before install
Not much else to say really. Would I get it again? Yes, it's priced competitively against the CF version (which I nearly pulled the trigger on) and the difference is something I can feel with the lighter DS. It's kinda like the first time you took your car out after slapping on sway bars...if that makes any sense..
Next on the list is a lighter clutch/flywheel and changing my final drive, then the car will be at the body shop for my exterior mods.
Cheers.
Old Jun 4, 2012 | 11:23 AM
kristinavq's Avatar
drive shaft shipped to 79936 03 5at coupe
Old Jun 4, 2012 | 12:16 PM
PAIXAO's Avatar
Please let me know when the M/T driveshafts are back in stock. I want one shipped to 20745 for a 2004 G35 Sedan 6MT.
Thank you!!
Old Jun 4, 2012 | 12:49 PM
RandomHer0's Avatar
When will there be stock for Coupe MT?
Old Jun 4, 2012 | 02:19 PM
Jairen's Avatar
Anyone have a DIY to swap the driveshaft? Seems like a simple project, but just want to make sure.
Old Jun 5, 2012 | 01:35 PM
Thank you!!
PMs Sent!
If you can install an exhaust, you can install our driveshaft IMHO. I haven't found a DIY for driveshaft removal yet, but if needed I can make one.
I just got word that we will be receiving a small shipment of driveshafts around the middle of next week, the ones that aren't already accounted for are expected to go quick. If you would like to reserve one of the driveshafts give our sales personnel a call. 770-838-7777 9am-6pm EST Mon-Sat
Old Jun 5, 2012 | 05:05 PM
Jairen's Avatar
Originally Posted by Z1Motorsports
PMs Sent!
Just want to make sure on the install. The only time I've had deal with the DS was to swap out diffs. Never delt with the transmission side of the DS.
Ship to FPO?
Old Jun 6, 2012 | 08:36 AM
Ship to FPO?
The Transmission side is even easier, its just a slip joint. Once the rear portion is unbolted, and you remove the 2 14mm bolts on the carrier bearing, the shaft just slips out.
PM sent!
Old Jun 7, 2012 | 09:32 AM
Sonicbounce17's Avatar
interested. saved for later use.
Old Jun 7, 2012 | 12:53 PM
Let me know if you have any questions!
Old Jun 7, 2012 | 02:45 PM
str8dum1's Avatar
who actually makes the the driveshafts and how may ft-lbs are they rated to. would like to go to a 1piece, but not if its gonna twistup.
Old Jun 9, 2012 | 02:43 AM
chiapet15's Avatar
Drive shaft for 05 G35 Coupe 6MT to 95035
Thanks!
Old Jun 9, 2012 | 11:44 PM
  #30
butkiss1's Avatar
Driveshaft to 91403
if there's not a lot in stock I'm willing to prepay immediately
