Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Nissan OEM Idler Pulley Elimination Kit
Old Jul 16, 2013 | 01:46 PM
Z1Motorsports's Avatar
This $48.00 kit eliminates your useless idler pully and frees up power!! If you want to free up power while you change your belts, this is a must! Include the A/C Belt by selecting the drop down tab. This is the OEM Spacer and Shorter OEM Belt Nissan used to eliminate the idler pulley from pre August 2006+(later models already have this delete from the factory) model VQ35DE Engines.
This kit can be found Here
Z1 350Z/G35 VQ35DE Lightweight Crank Pulley KIT
Z1 Motorsports 350Z/G35 Lighweight Aluminum Crank Pulley KIT for all VQ35DE equipped models.
Kit includes:
Z1 Lightweight Aluminum Crank Pulley
OEM Nissan Idler Pulley Delete Spacer
OEM Nissan Alternator Belt
OEM Nissan Air Conditioning Belt
Machined from 6061 Aluminum, the Z1 Motorsports 350Z/G35 Lightweight Crank Pulley is a great, economical weight to free up some extra horsepower from you VQ35DE power plant. Designed to take the abuse of the track and the street, the Z1 Motorsports Lightweight Crank Pulley address many of the issues that plague other crank pulley's on the market.
This kit can be found here HERE
Old Jul 16, 2013 | 02:49 PM
This is the OEM Spacer and Shorter OEM Belt Nissan used to eliminate the idler pulley from pre August 2006+(later models already have this delete from the factory) model VQ35DE Engines. The Spacer is placed in between the engine and the power steering mounting bracket in the space the idler pulley bracket would be normally.
By eliminating the idler pulley you remove almost 1lb of rotating mass from the engine and eliminate a wearing part that will eventually fail anyway. The idler pulley and bracket together weigh almost 3lbs.
This kit comes with ONE Nissan alternator belt and ONE idler spacer.
Old Jul 23, 2013 | 05:57 PM
Bump
Old Jul 23, 2013 | 07:55 PM
serges's Avatar
What size washer is that??
Old Jul 23, 2013 | 08:29 PM
Frankieg35's Avatar
Gonna order one soon..
Old Jul 24, 2013 | 09:32 AM
Sounds good, you can call in or order online.
Old Aug 6, 2013 | 11:00 AM
Going fast!!
Still a few in stock
Old Aug 12, 2013 | 09:58 PM
YT35's Avatar
I'll take one, pm me payment info
Old Aug 15, 2013 | 12:03 PM
PM's replayed
Old Sep 9, 2013 | 03:35 PM
Kits in stock
Old Sep 17, 2013 | 11:56 PM
JZ's Avatar
JZ
G35 Coupe KY0
How will this free up power for my 03.5 coupe?
Old Sep 18, 2013 | 09:43 AM
This $24.00 kit eliminates your useless idler pully and frees up power!! If you want to free up power while you change your belts, this is a must! Include the A/C Belt by selecting the drop down tab. This is the OEM Spacer and Shorter OEM Belt Nissan used to eliminate the idler pulley from pre August 2006+(later models already have this delete from the factory) model VQ35DE Engines.
Old Oct 17, 2013 | 07:17 AM
Al Janinny's Avatar
Hello, will it fit my 03 VQ35DE?
Why is needed additional spacer for steering pump, only shorter belt is not enough?
Old Oct 29, 2013 | 05:32 PM
Yes, this will fit your 2003 DE.
The spacer will take the space of the pulley bracket that you will no longer need.
