Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Brian Crower Valves,Springs,Retainers,Cams, STROKER KIT BIG SALE VQ35DE/HR
Old Sep 24, 2013 | 06:11 PM
THMotorsports's Avatar
Please add in the PM if it is a regular or HR engine.
PM ME FOR THE BEST PRICING ON G35Driver!
Brian Crower products come from a long heritage of working at the industry leader in performance engine designs, Crower Parts Inc. Brian used to head up the import division at Crower building many world record setting cams. He now branched on his own to form BC or Brian Crower, and we are more than happy to work together. We have a long held relationship with Brian regarding motor building and hope that you enjoy the cams.
The Stage II cams are rated to do about 20-25 whp. They are very similar to the JWT cams, but their midrange is much higher. There a few of these cams tested, and as you will see, the results speak for themselves.
STAGE II CAMSHAFTS: $PM FOR PRICE SHIPPED
Specs:
High Performance/Race
Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM spring OK. BC0221 264°/264° 222°/222° .426"/.426" 10.82/10.82 BC0220
VQ35DE (Nissan 350Z) Stock 256°/256° 208°/208° .375"/.375" 9.52/9.52
VQ35DE (Infiniti G35) Stock 258°/256° 210°/208° .378"/.375" 9.60/9.52
Stage Description Cam # Adv. Dur. Dur @ .050 Lift (in) Lift (mm) Kit #
VALVE SPRING/RETAINER KIT: $PM FOR PRICE SHIPPED
Designed for high rpm, BC valve springs are wound from only the highest grade, super clean, chrome silicone alloy and feature proprietary processing procedures for consistent pressures. BC titanium retainers are CNC machined from 6AL4V round bar titanium to exacting tolerances.
VALVES:
PM ME FOR PRICE Shipped for Intake
PM ME FOR PRICE Shipped for Exhaust
Part # Description #
BC3220 37.0mm Intake (standard head diameter)
BC3221 31.0mm Exhaust (standard head diameter)
BC3222 37.5mm Intake (+.5mm head diameter)
BC3223 31.5mm Exhaust (+.5mm head diameter)
VQ35DE / VQ35HR Sportsman Connecting Rods
PRICE: $PM FOR PRICE SHIPPED
Although the name implies that the Sportsman is a 2nd tier part, the Sportsman incorporates every feature of the premier BC625+ rod, only that the fasteners have been changed to the more economical, yet venerable ARP2000 bolt, rated to 220,000 p.s.i. The Sportsman is rated in excess of 200HP per cylinder and priced for the everyday performance buff.
C-to-C BE Bore BE Width PE Bore PE Width Gram Wt
BC6229 Nissan VQ35DE - Sportsman w/ARP2000 Fasteners 5.675" 2.165" .818" .866" .858" 540
BC6227 Nissan VQ35HR - Sportsman w/ARP2000 Fasteners 5.974" 2.224" .818" .866" .818" 558
VQ35DE / VQ35HR BC625+ Connecting Rods
The BC625+ rod from BC is the premier industry connecting rod. Incorporating ARP's ultimate fastener, the Custom Age 625+, rated to 280,000 p.s.i., the BC625+ delivers the ultimate clamping ability at high horsepower and rpm. This rod is intended for the true hardcore enthusiast and racer and is rated in excess of 300HP per cylinder.
BC6228 Nissan VQ35DE - BC625+ w/ARP Custom Age 625+ 5.675" 2.165" .818" .866" .858" 541
BC6226 Nissan VQ35HR - BC625+ w/ARP Custom Age 625+ 5.974" 2.244" .818" .866" .818" 559
VQ35DE CRANKSHAFTS
BC crankshafts are made from the finest, aerospace grade 4340 steel billet material. CNC machined on state of the art, 5 axis Mazak Integrex 300-IV CNC machines to exacting tolerances (.0001"). Every crankshaft features large radius journals that add rigidity for high horsepower, high boost, high rpm applications. Gun drilled, CNC ground oil holes feature a smooth surface for extra oiling, tear dropped for added oil scoop, cross drilled for priority main feeding to the rods and micro polished to a mirror finish for optimum bearing lubricity. All cranks are stress relieved, shot peened, magna flux inspected and nitrided (multi step heat treatment) for ultimate performance. Fully profiled counterweights are designed for reduced windage through the crankcase creating less oil resistance for better rpm potential.
Stroke Crank Pin Main
BC5225 CRANKSHAFT - Nissan VQ35DE, 4340 Billet, Fully Balanced 86.4mm 51.97mm 59.96mm
BC5225U CRANKSHAFT - Nissan VQ35DE, 4340 Billet, Unbalanced 86.4mm 51.97mm 59.96mm
BC5227 CRANKSHAFT - Nissan VQ35HR, 4340 Billet, Fully Balanced 86.4mm 54mm 64.96mm
BC5227U CRANKSHAFT - Nissan VQ35HR, 4340 Billet, Unbalanced 86.4mm 54mm 64.96mm
The Big Bertha 4.15L stroker Kit!!!
The BC stroker kit for the Nissan VQ35DE engine platform incorporates a 88mm stroke, steel billet crank, BC 4340 Pro Series Billet rods rated to 1200+ horsepower. Depending on bore size that you decide, the BC kit will take you up to a 4.15L with 100mm bore. As usual, each BC kit features custom CP aluminum forged pistons, 9310 alloy wrist pins, ring pack and buttons. Available in any desired bore and compression ratio for use in turbo or normally aspirated.
How to order?: Call me at 1-800-959-0145 ext 102 ask for Alan
We Paypal to checkout online, just PM us with your email!!!
1. Call 1-800-959-0145EXT 102 toll free and mention the sale
**Master Card, Visa, Discover, AMEX** OR PM US!!!!!!!
EMAIL: acastro@thmotorsports.com
WE ALSO USE AIM: AlancTHM
Old Sep 25, 2013 | 07:14 PM
All pm's are out!!! Have a good day!!! PM me for the BEST PRICING ON THE WHOLE FORUM!!! Making deals every day!!!!
Old Sep 26, 2013 | 06:16 PM
Bump!!! Friday tomorrow finally!!! Pm me lets make a deal!!!!
Old Sep 27, 2013 | 06:41 PM
Have a great weekend all! PM me for the best pricing all over the forum! Lowest and free shipping with in the USA!!
Old Sep 29, 2013 | 08:39 PM
Hope everyone had a good weekend! Pm me for the best deals! You need something let me know we got the best deals!!!
Old Oct 1, 2013 | 06:24 PM
Pm's are out! Best pricing guaranteed if someone has a cheaper price we will BEAT IT!
Old Oct 3, 2013 | 09:56 PM
Need some parts? PM ME! We got the BEST deals hands down!!!
Old Oct 8, 2013 | 06:11 PM
Lets get this bumped up!!!! Pm me lets make a deal!!!!
Old Oct 10, 2013 | 10:09 PM
New quotes are out pm me for the best deals!
Old Oct 16, 2013 | 07:20 PM
PM'S are out!!!! Best prices for October!! HALLOWEEN SPECIALS!!
KevinnnVo
Jul 28, 2015 06:29 PM
joel extreme
SOCAL Meetings & Events
Jul 27, 2015 11:59 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Ashton35
Jul 22, 2015 09:19 PM
