Exterior-Vendor Includes spoilers, body kits, tail lights, gauges, shift knobs, and other styling components
Aluminum Under Tray (Splash Shield) for G35/350Z/G35X/G37/G37X
Old Apr 6, 2015 | 12:53 AM
  #781
07Nismo350gt's Avatar
How much for the g35 coupe undertray in black shipped to 92345
Old Apr 6, 2015 | 10:42 PM
  #782
Tolboothwilley™'s Avatar
Black version for the G35 coupe/sedan (same) - also fits the 350Z the same
link:
http://www.tollboothwilley.com/nissa...er-tray-black/
Old Apr 20, 2015 | 11:09 PM
  #783
bump
Old Apr 28, 2015 | 01:26 AM
  #784
Black Powder coated version for the G35 / 350Z
Old Apr 28, 2015 | 04:31 PM
  #785
SUMBLAKDUDE's Avatar
Tray
Aluminum tray for 05 coupe shipped to 35235
Old Apr 28, 2015 | 05:48 PM
  #786
redguitarfreak's Avatar
LOVE my red powdercoated version. Be jealous!
Old Apr 28, 2015 | 06:41 PM
  #787
StuttersC's Avatar
Looks very nice. Having just changed my oil and dealt with the flimsy, poorly attached stock one, this looks like a worthwhile investment.
Old Apr 29, 2015 | 02:30 PM
  #788
I spy some ART pipes and aftermarket sways on there also! looks great
looks like you swapped your compression rod bushings, have you done the lower control arm and rear differential yet?
You're one of the few who still have the oem one attached probably. A lot of us lose them on the highway. They rip off the bumper at high speeds as they get worse over time.
Old Apr 29, 2015 | 02:47 PM
  #789
Yeah that red matches up nicely!! Cemented the fact that red is going to be my accent color.
Compression arm bushings are done, yes. LCA bushings were done literally minutes after this picture. Lol. It was next on our list. I'll be doing the outer(strut bushing) here soon, as well as tie rods and ball joints. Just to hit every nail on the head.
Is the diff bushing always something worth doing? Or just when it wears out. I currently don't have any leaking from back there but it is on the list.
Old Apr 29, 2015 | 03:43 PM
  #790
Diff bushing will leak if it hasn't. It is a very common problem.
when you're ready:
http://www.tollboothwilley.com/nissa...-rear-bushing/
Use coupon code WHITELINE for discount and free shipping
Old Apr 29, 2015 | 07:42 PM
  #791
StuttersC's Avatar
.....You're one of the few who still have the oem one attached probably. A lot of us lose them on the highway. They rip off the bumper at high speeds as they get worse over time.
I bought my car used, and it was babied, but the stock one was a pain to get off with missing, or messed up clips and jacked up bolts. Putting it back on was not any easier. I had three bolts left over, and there was no way they were going back in. They wouldn't attach to anything again.
So, I guess I need to save up for the fastener kit as well.
Old May 16, 2015 | 02:22 PM
  #792
There is currently a promotion going on:
G35 Aluminum Splash Shields
Enter: ILOVELAMP as a coupon code at checkout for immediate discount!
Old Jun 3, 2015 | 04:21 PM
  #793
hdmark's Avatar
Would anyone have any pictures of the mounting points? For some reason, I feel like im missing clips or something where the bolts should go to the frame.
Also, for my kuruma Z, I should be mounting the undertray to the bottom of the bumper right? And then attaching the speed nut/ clips to the bumper? or should the bumper be on the bottom and the speed clips attach to the tray itself?
Thank you!
Old Jun 3, 2015 | 08:19 PM
  #794
there are no clips for the bolts that connect to the frame - the frame has threaded holes
Most people mount the front piece UNDER the bumper so it helps hold it up. There are those who have mounted it above as well though. Holes in bumper - slide speed nuts in place(on bumper) then put metal piece up and attach with bolts.
the fender liners should also have mounting speed nuts
Old Jun 4, 2015 | 08:48 AM
  #795
hdmark's Avatar
Is the lower radiator support threaded or are there plugs/clips that sit in it that have threads? I think that's where I'm having an issue. I think there are just large holes/no threads in those spots where the 3 center bolts go between the 2 different sections of undertray
Also - there is a lot of excess material in the kuruma bumper (my guess is to make sure it reached the undertray) but since it is so far, its hard to get a speed nut on , should I just cut the material away using a dremel/scissors (its a poly bumper)? or is there a better way?
Thank you again for the continued help with this!! I love this undertray and have had it on for about 2 years now !
