FAQ & DIY Frequently Asked Questions & Do It Yourself- Sedan and Coupe. Updates Approved by Administrators and Moderators.
Changing fog light bulbs
Old Aug 27, 2002 | 02:18 PM
nadz240's Avatar
Can anyone give me a step-by-step on how exactly to change the fog light bulbs. I've heard that the wheels need to be turned to one side and the fender taken off but I can't visualize exactly what needs to be done and I don't want to start taking apart my G and find out I can't put it back together :-). Thanks for any help!
nadz240's Avatar
Re: Changing fog light bulbs
The Infiniti rep called me back last night in response to the misprint in the manual that I had told her about. Well they are gonna fix the manual and she is sending me a 15000mile service voucher to make up for my lost time. I must say that Infiniti Customer Service has yet to disappoint me. Most other car companies would have just said thanks for the info and have a nice day but they went the extra mile. Well as long as they keep making great cars, I'll be there to buy 'em!! :-)
Old Nov 25, 2002 | 05:15 PM
Guru's Avatar
Actually yes there are lo/hi beam H4 HID's available. They are slightly more than the regular single beams and will work fine for high beam/fog lights. I carry the Catz units which are made in Japan and are the nicest ones available but there are other manufacturer as well. I know US spec cars are H4/HB3 but not sure on Canadian.
Dan
99 GS400
02 WRX
Old Jan 2, 2003 | 05:35 PM
KongzGx's Avatar
i thought the G had H1 bulbs for lows and HB4/9006 bulbs for high/fog.
'03 G35 Sedan: ivory/aero body/sport/sunroof
Warning: Objects in mirror are FASTER than they appear
Old Jan 6, 2003 | 11:58 PM
nadz240's Avatar
The fog light bulb is a misprint in the manual. They are actually H4/9003 bulbs.
Old Jan 7, 2003 | 07:39 PM
pestilence's Avatar
yep yep.
..pestilence..
Old Jan 8, 2003 | 12:36 PM
VNT's Avatar
VNT
If you look at the headlight lens, on the bottom it lists the two bulbs: D2R and HB2
Old Jan 10, 2003 | 11:09 AM
KongzGx's Avatar
wait, i'm confused.. d2r and hb2? what car has these bulb types?
what's the difference between d2r and h1?
Old Jan 10, 2003 | 01:32 PM
Gordgee's Avatar
Administrator
Hope this helps for future references: [img]/w3timages/icons/smile.gif[/img]
Headlight bulb cross reference
9003 is also referenced to as a H4 also is a HB2
9004 is also referenced to as aHB1
9005 is also referenced to as a HB3
9006 is also referenced to as a HB4
9007 is also referenced to as a HB5
H.I.D bulbs are referenced as 9500, D2R, D2S
H1,H2,H3, and H7 are referenced as such
H99 is H-99 side marker bulbs
6053,6054,6052,5054, type 2B1= 7X6" sealed beam (7 7/8"x5 5/8")
4652,4662, 4656, 5062 , type 2A1= 4 X6" (4" x 6 1/2")
Old Jan 10, 2003 | 01:35 PM
KongzGx's Avatar
cool.. thanks
Old Jan 24, 2003 | 12:25 PM
Marcel's Avatar
The wedge bulb almost has a purple tint to it. Is that due to the lighting? How bright is the wedge bulb compared to the stock one?
Marcel
Old Jan 24, 2003 | 03:31 PM
pestilence's Avatar
very nice kkh713x.
..pestilence..
Old Jan 25, 2003 | 02:22 AM
  #30
VNT's Avatar
VNT
KongzGx....I should have been clearer...with HID's....
a D2R is the HID capsule for a reflector based system. There is a sheild on the capsule that blocks most of the light from hitting the lower portion of the headlight reflector. This area is generally useless.
a D2S, has no shield, and is for projector systems (like BMW & Audi).
the 350Z, is more like a hybrid projector-reflector system that uses a D2R capsule.
