spring/sway install
Old Jul 4, 2006 | 10:51 PM
w0ady's Avatar
fgc moderator
spring/sway install
well im pretty set on my decision of tein 350z h-techs and stillen sways. now its just a matter of deciding when.
what i wanted to know was if anyone in north/central florida wouldnt mind helping me install them? im sure the sways arent tough, but ive never done springs and id rather have someone with some experience help. id be willing to drive a couple of hours to orlando or something. i could also pay in beer heh.
Old Jul 4, 2006 | 11:20 PM
Dakkerz's Avatar
If you were closer to Sarasota I'd help you out for beer , but instead I can offer you up a nice write-up that Gsedan35 did.
https://g35driver.com/forums/showthr...ghlight=cotter
I think this just shows his revision on making the front spring install easier. There is a link at the top that shows the original write-up with instructions on how to install the rear springs.
I used this to install my Tein coilovers and it helped out a LOT!
Old Jul 4, 2006 | 11:57 PM
Audible Mayhem's Avatar
sway bar bolts are on pretty tight, much easier with air tools.
Old Jul 5, 2006 | 01:27 AM
Jamaica2G's Avatar
springs are easy... but we need air tools ... unless you want me to just point and you do the labor for hours and hours of spring compression?!
lol
but seriously, an air gun would make it much easier to deal with... who's got a compressor?!
Adrian
Old Jul 5, 2006 | 03:52 AM
w0ady's Avatar
fgc moderator
im just using this as an excuse to meet some fgc guys. hopefully i can find someone/somewhere we can do this. if all else fails, i think my buddy has everything at his parents house in southern ga.
Old Jul 7, 2006 | 08:34 PM
w0ady's Avatar
fgc moderator
problem...i was all set on 350z h-techs but i was doing some reading and i just realized something. with my 05 sport suspension, almost any spring i go with will have a lower rear rate and i dont want that. my main goal with springs is to reduce my tire gap without going low enough that i need camber adjustments. so far, it looks like my only option is a split spring set such as h-techs front and eibach pros rear. anyone have any advice?
Old Jul 8, 2006 | 09:11 AM
Gilley's Avatar
I think OEM Z springs will have the same spring rate but will lower it some.
Old Jul 8, 2006 | 12:30 PM
SFLG35's Avatar
FGC President
wrong
jason tried this but it looks like his car got a lift kit in the rear.
the z front springs will lower the car about an inch in the front but the rears are exactly the same. the springs are the exact same size and they will not lower the rear it all. so the front will look lowered but hte rear will actually look like it was raised up a little bit.
Old Jul 8, 2006 | 01:09 PM
chobble19's Avatar
Thumbs up my main goal with springs is to reduce my tire gap without going low enough that i ne
i was thinking the same when i decided to purchase a set of springs for my 6MT sedan....especially since the rear is slightly lower on sedans. the drop was 1.3 front/0.7 rear and the rear still looks a mm or 2 lower than my front b/c of the 245/40/19 on my rear coupe wheels and 225/40/19 front. i have some rubbing issues when 3+ people so i will probably end up having my rear fenders rolled and also replace tire size to 245/35/19 instead of 245/40/19. i havnt had an alighnment since the springs and coupe wheels were put on, no camber issues and besides being noisy everythings fine.
Old Jul 8, 2006 | 08:39 PM
w0ady's Avatar
fgc moderator
i understand that chobble, but i cant justify hurting my handling just for looks. as much as i want the springs for cosmetics, i wont sacrifice performance. bah this really sucks...
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
