I could use some help asap... VDC, ABS, slip lights all on
Old Dec 8, 2006 | 04:25 PM
stpdevil's Avatar
https://g35driver.com/forums/showthr...06#post1574106
I'm calling lokey now.
Old Dec 8, 2006 | 04:47 PM
stpdevil's Avatar
blown brake light fuse... everything is good now
Old Dec 8, 2006 | 09:40 PM
98intrigue's Avatar
I was doing 130+ last night on I4 when all my lights went on. My car stalled...in a turn! No ABS was quite scray. Luckily I knew what was going on from reading on the forums and didn't freak out. Well, maybe a little...
Old Dec 8, 2006 | 10:43 PM
stpdevil's Avatar
What was the problem?
Old Dec 9, 2006 | 08:42 AM
Jamaica2G's Avatar
my guess is stillen CAIntake and he put it in Neutral... if you do that, the car will shut off at that speed.
Adrian
Old Dec 9, 2006 | 11:33 AM
stpdevil's Avatar
Adrian
That was my guess as well
Old Dec 10, 2006 | 06:35 PM
98intrigue's Avatar
I have a z-tube with a K&N filter.....guess again?
Old Dec 10, 2006 | 07:02 PM
stpdevil's Avatar
I have no idea.
Old Dec 10, 2006 | 08:54 PM
Gilley's Avatar
You turned off the ignition be accident?
Old Dec 11, 2006 | 11:51 AM
Ill_legal's Avatar
I have this same problem right now. When the three light come on it's an indicator that your brakes need service. My brake fluid is low and I need to replace the front rotors and pads all the way around. I wish my problem was a blown fuse..
Old Dec 11, 2006 | 12:44 PM
stpdevil's Avatar
Well I just had my brakes replaced 2 days before.
Old Dec 11, 2006 | 01:46 PM
Ill_legal's Avatar
Cool, I would take your car back and have them check your brake fluid and look over your brakes.
Old Dec 11, 2006 | 03:58 PM
stpdevil's Avatar
I checked em... its was all good. Just the fuse (it was my fault).
Old Feb 25, 2008 | 04:10 AM
cpugangster420's Avatar
Could use some help too
Well got a similar problem, vdc and slip lights on. The damn brakes come on and make a loud grind sound when I first start driven the car. I have checked emerying, brake fluid, pads and rotors. Only work done on the car was sub frame, rack and pinion being replaced. Hooked to a tool and no codes come up, thinken it might be my vdc/abs sensor......any other ideas
Old Feb 25, 2008 | 05:50 AM
w0ady's Avatar
fgc moderator
yea make sure your speed sensor is aligned well and tightened down on the inside of the front rotors.
