dynoed the car today
first run.. max power - 247.94 max torque 229.82
second run.. max power - 248.95 max torque 231.45
third run.. max power - 251.25 max torque 229.55
Originally Posted by ZUL8R
Impressive considering you are running 20's. WHat kinda dyno and what kinda corrections?
isn't 03 around ~260hp? If so, it would be close to 220rwhp taking out a little extra for the trans.
I have seen all kinds of numbers depending on the car, conditions, and dyno.
I put down a best of 212rwhp with just ztube and filter on a mustang dyno.
Mine is 03 sedan-auto. Dyno jets usually dyno about 10-15 hp more.
I think the difference is that the dyno jet is a free rolling spindle and the mustang dyno simulates road resistance.
Originally Posted by Psycraft
03 auto
do you have your dyno sheets, it will say what correction, that is pretty high for an auto with no ecu for tuning, especially with 20s but these ECUs do some weird stuff and if you catch them on the right day with the right weather, you can get some good numbers...
they dyno definitely didnt reset the ecu, it is probably in your head cause you saw that those are pretty good numbers for what you have and that it felt faster..
did your dyno graph spike up right at the end when the guy let off the throttle, it will give a false high reading sometimes.
post your graphs though when you can
