Anyone have a idea whats wrong my brake/vdc/slip light are on!
Old Jul 15, 2007 | 09:33 PM
Jum's Avatar
Jum
Florida G35 Owner
Anyone have a idea whats wrong my brake/vdc/slip light are on!?!?!?!?
Old Jul 15, 2007 | 10:03 PM
ScubaSteve312's Avatar
happened to me a month ago, kept coming on and off periodically.
decided to seek help from the dealership and my local autoshop and they discovered i was long overdue for new brake rotors/pads.
some people here on the forum will insist your brake fluid must be low but I'd get the pads checked by the local autoshop (or yourself) just in case.
Old Jul 15, 2007 | 10:05 PM
Jum's Avatar
Jum
Florida G35 Owner
im going to the dealership tomororw
Old Jul 15, 2007 | 10:22 PM
w0ady's Avatar
fgc moderator
this just happened to me when i got my camber kit installed. it is possibly 1 of 2 things - either your speed sensor bracket is bent or it is simply misaligned. if you have messed with your front assemblies then this is most likely the cause. if they came on all of a sudden, then scuba is probably right.
Old Jul 15, 2007 | 10:25 PM
as long as it doesn't mess up the warranty I'd strongly recommend getting it done at the local shop if they're reliable and fair. got my transmission fluid changed, back rotors refurbished and front rotors replaced along with the brake pads for $550 at the local place. Dealership quoted me $850...just puttin that out there.
Old Jul 15, 2007 | 10:40 PM
Jum's Avatar
Jum
Florida G35 Owner
well its a lease and its underwarranty so it sould be ok
Old Jul 15, 2007 | 11:53 PM
srsly's Avatar
same thing happened to me
Old Jul 15, 2007 | 11:57 PM
GreenGoblin's Avatar
The goblin resurrection
it usually is the break fluid of check the sensor on the dif
chinee
Jun 10, 2024 07:48 PM
Ray Feta
Aug 20, 2015 08:46 PM
Wayne9011
Jul 27, 2015 11:25 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
