To those who haven't done the headlight recall yet, please read!!
Old Nov 17, 2007 | 08:54 PM
DefJux921's Avatar
i know this is kinda old thread but there was some misleading information in here - the recall replaces the headlights, NOT the bulbs. you keep your same bulbs. like somebody else said, it has to do with the cutoff which is internal and has nothing to do with the bulb. after my recall my headlights were aimed way too low - but its easy to aim 'em yourself. i also had a slightly larger gap on the driver side but its just a couple of bolts to fix... sucks to hear about the scratches... did they buff 'em out for you?
Old Nov 18, 2007 | 09:55 AM
Jamaica2G's Avatar
First time I've seen this thread and I'm glad you said it before I did...
If I remember correctly, the recall was about the light that goes off to the far left and far right...but mainly the far left... why? because this light goes into the eyes of oncoming traffic @ certain situations.
If you have the old lamps, you'll see that the light on the outskirts goes up high - not the best design for well lit streets in very populous areas but they work very well for roads/highways w/o lighting like the turnpike and anywhere 5 miles outside of Gainesville :-D
old light pattern
\_______/
Recall light pattern
--_______-- or _______ (I haven't looked hard enough)
Just make sure they are aimed correctly (which I haven't done)
Hope this helps
Adrian
Old Nov 18, 2007 | 03:56 PM
QuadCam's Avatar
Originally Posted by JOKER
Infninitis main objective was to replace the bulbs, I don't know why they replaced the entire headlight.
I don't think so. I think it had to do with the placement of the projector. They were too far back and didn't have a very good beam pattern. Infiniti has also recalled some of their other vehicle heedlights for similar issues.
Old Nov 20, 2007 | 09:15 PM
sameo2's Avatar
any headlamp from infiniti vehiclesdo not say infiniti. we rpl the headlamp assy no light bulb. the gap is the guy who installed dont care about hes job done property.and the aim issue take the car back the y will fix for u if is a big issue for u.
Jusseth
Sep 13, 2020 12:25 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
youngdip631
Lighting
Aug 27, 2015 03:49 PM
newg37
Jul 26, 2015 09:32 AM
lilscsteve
Jul 21, 2015 04:01 PM
