help finding tires...
You can put your stock 18's up front and leave your 19's in the rear since the tire diameters for the 18's should be the same as the 19's were.
I would recommend SPC or Cusco front camber arms, which cost around $400 and Eibach rear camber arms, which cost about $145 and are made by SPC and come with toe bolts.
I got my toyo T1R's from www.td4l.com
He's a sponsor here on the boards...PM TD4L
I believe they ran $830ish for 4. You run the same setup as me.
PMed him...another question, when referring to a camber kit, are we talking about getting the upper A Arms and thats it? confused, and where do i go to get it adjusted, any place that does alingments will do it? thanks!
I have an '05 AT, with custom wheels and tires (19x8.5/9.5 and 255fr/285rr), and have the TEIN 350z S springs. I do not need a camber kit. I have no uneven wear at all...
Originally Posted by r10apple
I am still trying to figure out why you NEED a camber kit? Is your car lowered? If so, how (what product)?
Falken 452s. They seem to be fine for me. Unfortunately, the closest sizes are 255/30 and 275/30
http://edgeracing.com/tires/2553020/
http://edgeracing.com/tires/2753020/
Originally Posted by Gilley
Every car is different...which was within alignment specs.
But you are right, Sean, every car is a bit different...
so should i get the upper a arms or just get new tires and an alignment? thanks for all the grea info guys, glad im on these boards
Just my opinion...
Try Sean @ speed zone. He's good friends with the ozoc crew .Ive got 20's on my g and i put 255's on the front and 275's on the rear for like $585 out the door. they were nankang tires but they are actually pretty decent compared to others from what other people on the forums have said. speed zone's number is 407 846 8430
eljefe7070g35
Sep 11, 2015 09:28 AM
G35VSHNG37
Sep 10, 2015 01:54 PM
