help finding tires...
Old Oct 22, 2007 | 05:19 PM
BLacK_G35_CouPe's Avatar
yea another thread about me needing something but arent the forums made for this reason
well never noticed how bad my camber was untill adrian pointed it out saturday while installing my headlamps, and well decided to go to Discount Tire to see if they can switch the fronts. they wouldnt because one of tires is real bad. so got an estimate on 4 tires with the specs in my sig, $1120. and that sucks lol, thinkin about going with a diff company than Toyo, so if any has any recommendations or brands or places that sell tires, please let me know. i can probably get away with just 2 fronts for now, and that will run around 350-450. thanks again guys
Old Oct 22, 2007 | 05:24 PM
w0ady's Avatar
fgc moderator
you could try ordering online - http://www.edgeracing.com/
just make sure you check prices for install before you buy so you dont get raped.
or check with dan (sflg35) - he might have something cheap.
i go to tk performance usually but they are still about $250/tire.
Old Oct 22, 2007 | 09:45 PM
NathanJax's Avatar
..... I WIN .....
My dad's a mechanic... I'll see about a price tomorrow morning...
Old Oct 22, 2007 | 09:47 PM
express705's Avatar
i got a guy in miami that supplies my tires... ill get a quote if your willing to get them...
Old Oct 22, 2007 | 09:53 PM
black_sedan's Avatar
i'd say try running the General Exclaim UHPs. Tire rack has them for $125 each in your size. You'll probably be right at $300 for the pair shipped and installed.
Old Oct 22, 2007 | 10:43 PM
SFLG35's Avatar
FGC President
i need 255 30 20 285 30 20
Old Oct 22, 2007 | 11:08 PM
express705's Avatar
YOU??? need tires??
how is this possible?? i think im at the nexus of the universe!
Old Oct 22, 2007 | 11:28 PM
SFLG35's Avatar
FGC President
lol
yes i need tires for my 20s which should be here shortly!!
i finally got rid of the nittos, but still hav ethe nevens left. want to buy them from me.
Old Oct 22, 2007 | 11:46 PM
express705's Avatar
no.. want to buy the tires you need from me? =)
Old Oct 23, 2007 | 01:23 AM
Jamaica2G's Avatar
Not sure if this link still works. It was a $100 discount off of a set of 4
http://www.discounttiredirect.com/direct/webOffer.do
Good luck dood
Adrian
Old Oct 23, 2007 | 02:00 AM
thanks all, yea if its not a big problem please shoot me some estimates you guys are great help out SFL too lol.
^ as you can see my camber is off enough to completely bald the interior side of my tires sucks that i never realized it, gatta get that TK performance alignment package that i heard about. yea adrian the guy i talked to today at Discount tire quoted me 1120 with the discount for Toyo T1Rs...real steep, but i guess you get what you pay for.
thanks again guys, always willing to help a fellow g memeber in need
Old Oct 23, 2007 | 10:18 AM
Gilley's Avatar
^ The front camber isn't adjustable, so no alignment package is going to cure your tire wear issue without a camber kit up front. You might as well get the rear camber kit too (it's a lot less expensive) since your rear tires are probably doing the same thing. If you stay away from the ultra expensive Stillen camber kits, in the long run, a camber kit will be less expensive than buying tires more frequently than normal because the insides wore out.
BFG KDW2's are about the least expensive tire that carries those sizes. Otherwise you can go with Shermie's slightly wider and taller 295/30/20 in the rear.
Old Oct 23, 2007 | 11:26 AM
well damn...hey gilley which camber kit would you recommend for the money? also i thought alignments took care of lining up the wheels to lay on the road flushly? i have not gotten an alignment in over a year and a half (since i first got the tires, yea shame on me). your knowledge is always great to have gilley, please inform me more! thanks alot man
Old Oct 23, 2007 | 11:28 AM
o yea, im going to just install my stock 18s with about 40% tread left untill i get this all situated, workin on gettin money for tires and camber kit now...would it be alright to install my front 18 stockers and leave the 19s in the back? because i do wanna wear out the backs enough to make it worth while to replace all 4 tires and install the camber kits...thanks
Old Oct 23, 2007 | 12:11 PM
r10apple's Avatar
Call my buddy Dennis at 904-786-0721/904-219-1767. He is the GM of Big Chief tire, though he is in the Normandy Blvd location. They do tires, alignments, etc...
Anyway, they can get anything you want, but certainly, certain tires are cheaper than others, and those on hand are cheaper then custom ordered stuff. I have run Nittos and they are always solid. I have also had Maxxis and Cooper in the past. I am currently running Goodyear run-flats on the back (Corvettes changed, so we got them for a DEEP discount) and Michelin on the front (very pricey, but very good).
I am pretty sure that you can get Nittos for under $1100 installed. Just call him and tell him Cass told you to call...
