JAX - video card help
Old May 27, 2008 | 08:26 PM
  #31
w0ady's Avatar
fgc moderator
pc boots up and beeps. monitor doesnt come on because its not receiving a signal. im leaning towards the vid card because of that. until i prove thats not it and then i cry because its my motherboard.
Old May 27, 2008 | 08:56 PM
  #32
DiamondGCoupe's Avatar
Try popping out the MB battery, I've done that twice on my friends' computers and the damn things booted up perfectly. Hard to tell but since you mentioned the card causing problems before the is most likely the problem.. I'm sure it's time for an upgrde just go pick a new card up lol
Old May 27, 2008 | 11:56 PM
  #33
hotsauce's Avatar
if it boots up and beeps like normal then it probably is something besides your mobo. If you have more than 1 ram chip try taking one out and using the other. If that does not work swap out the other. I can't tell you how many hours have been wrapped up in bad ram.
I would also try resetting the cmos battery and jumper. Your mobo instruction manual should tell you how.
BTW
You said you have a 6800GTX. It has been a while but I never knew they made those in PCI express flavors just AGP. That means the card you want won't fit unless you have a hybrid. What mother board are you using?
Old May 28, 2008 | 02:16 AM
  #34
BLacK_G35_CouPe's Avatar
when i put my computer in sleep mode and try to turn it back on, my monitor does not get signals after that. so i unplug my video cards power cord going into the mobo, than plug it back in. than it works fine.
you said it beeps, look up the beep codes online to see what it corresponds too. i might have an extra card or 2 in the garage lyndon, but gatta let me know if your using AGP or PCI, give us your specs man!
Old May 28, 2008 | 03:31 AM
  #35
mdemonte's Avatar
AMI BIOS beep codes
Beep Code Descriptions Document
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
link for info http://www.computerhope.com/beep.htm
AWARD BIOS beep codes
Beep Code Description Document
1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information CH000607
Any other beep(s) RAM problem. CH000996
Phoenix BIOS beep codes
Beep Code Description / What to Check
1-1-1-3 Verify Real Mode.
1-1-2-1 Get CPU type.
1-1-2-3 Initialize system hardware.
1-1-3-1 Initialize chipset registers with initial POST values.
1-1-3-2 Set in POST flag.
1-1-3-3 Initialize CPU registers.
1-1-4-1 Initialize cache to initial POST values.
1-1-4-3 Initialize I/O.
1-2-1-1 Initialize Power Management.
1-2-1-2 Load alternate registers with initial POST values.
1-2-1-3 Jump to UserPatch0.
1-2-2-1 Initialize keyboard controller.
1-2-2-3 BIOS ROM checksum.
1-2-3-1 8254 timer initialization.
1-2-3-3 8237 DMA controller initialization.
1-2-4-1 Reset Programmable Interrupt Controller.
1-3-1-1 Test DRAM refresh.
1-3-1-3 Test 8742 Keyboard Controller.
1-3-2-1 Set ES segment to register to 4 GB.
1-3-3-1 28 Autosize DRAM.
1-3-3-3 Clear 512K base RAM.
1-3-4-1 Test 512 base address lines.
1-3-4-3 Test 512K base memory.
1-4-1-3 Test CPU bus-clock frequency.
1-4-2-4 Reinitialize the chipset.
1-4-3-1 Shadow system BIOS ROM.
1-4-3-2 Reinitialize the cache.
1-4-3-3 Autosize cache.
1-4-4-1 Configure advanced chipset registers.
1-4-4-2 Load alternate registers with CMOS values.
2-1-1-1 Set Initial CPU speed.
2-1-1-3 Initialize interrupt vectors.
2-1-2-1 Initialize BIOS interrupts.
2-1-2-3 Check ROM copyright notice.
2-1-2-4 Initialize manager for PCI Options ROMs.
2-1-3-1 Check video configuration against CMOS.
2-1-3-2 Initialize PCI bus and devices.
2-1-3-3 Initialize all video adapters in system.
2-1-4-1 Shadow video BIOS ROM.
2-1-4-3 Display copyright notice.
2-2-1-1 Display CPU type and speed.
2-2-1-3 Test keyboard.
2-2-2-1 Set key click if enabled.
2-2-2-3 56 Enable keyboard.
2-2-3-1 Test for unexpected interrupts.
2-2-3-3 Display prompt "Press F2 to enter SETUP".
2-2-4-1 Test RAM between 512 and 640k.
2-3-1-1 Test expanded memory.
2-3-1-3 Test extended memory address lines.
2-3-2-1 Jump to UserPatch1.
2-3-2-3 Configure advanced cache registers.
2-3-3-1 Enable external and CPU caches.
2-3-3-3 Display external cache size.
2-3-4-1 Display shadow message.
2-3-4-3 Display non-disposable segments.
2-4-1-1 Display error messages.
2-4-1-3 Check for configuration errors.
2-4-2-1 Test real-time clock.
2-4-2-3 Check for keyboard errors
2-4-4-1 Set up hardware interrupts vectors.
2-4-4-3 Test coprocessor if present.
3-1-1-1 Disable onboard I/O ports.
3-1-1-3 Detect and install external RS232 ports.
3-1-2-1 Detect and install external parallel ports.
3-1-2-3 Re-initialize onboard I/O ports.
3-1-3-1 Initialize BIOS Data Area.
3-1-3-3 Initialize Extended BIOS Data Area.
3-1-4-1 Initialize floppy controller.
3-2-1-1 Initialize hard-disk controller.
3-2-1-2 Initialize local-bus hard-disk controller.
3-2-1-3 Jump to UserPatch2.
3-2-2-1 Disable A20 address line.
3-2-2-3 Clear huge ES segment register.
3-2-3-1 Search for option ROMs.
3-2-3-3 Shadow option ROMs.
3-2-4-1 Set up Power Management.
3-2-4-3 Enable hardware interrupts.
3-3-1-1 Set time of day.
3-3-1-3 Check key lock.
3-3-3-1 Erase F2 prompt.
3-3-3-3 Scan for F2 key stroke.
3-3-4-1 Enter SETUP.
3-3-4-3 Clear in-POST flag.
3-4-1-1 Check for errors
3-4-1-3 POST done--prepare to boot operating system.
3-4-2-1 One beep.
3-4-2-3 Check password (optional).
3-4-3-1 Clear global descriptor table.
3-4-4-1 Clear parity checkers.
3-4-4-3 Clear screen (optional).
3-4-4-4 Check virus and backup reminders.
4-1-1-1 Try to boot with INT 19.
4-2-1-1 Interrupt handler error.
4-2-1-3 Unknown interrupt error.
4-2-2-1 Pending interrupt error.
4-2-2-3 Initialize option ROM error.
4-2-3-1 Shutdown error.
4-2-3-3 Extended Block Move.
4-2-4-1 Shutdown 10 error.
4-3-1-3 Initialize the chipset.
4-3-1-4 Initialize refresh counter.
4-3-2-1 Check for Forced Flash.
4-3-2-2 Check HW status of ROM.
4-3-2-3 BIOS ROM is OK.
4-3-2-4 Do a complete RAM test.
4-3-3-1 Do OEM initialization.
4-3-3-2 Initialize interrupt controller.
4-3-3-3 Read in bootstrap code.
4-3-3-4 Initialize all vectors.
4-3-4-1 Boot the Flash program.
4-3-4-2 Initialize the boot device.
4-3-4-3 Boot code was read OK.
Old May 28, 2008 | 03:33 AM
  #36
mdemonte's Avatar
More info
COMPUTER SYSTEM BEEP CODES
Beep Code: Description of Problem:
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
Old May 28, 2008 | 05:53 AM
  #37
w0ady's Avatar
fgc moderator
omg info overload lol.
pretty sure it was pci-x. 6800 gt or gtx. i bought it off someone else so thats why i dont remember everything exactly.
Old May 28, 2008 | 01:42 PM
  #38
what motherboard u got lyndon? i have an AGP card in the garage, ill look for them after i cut the grass
Old May 28, 2008 | 05:50 PM
  #39
w0ady's Avatar
fgc moderator
um no idea.
Old May 28, 2008 | 08:33 PM
  #40
im guessin since u dont know u bought it already made huh? who makes it?
Old May 28, 2008 | 10:24 PM
  #41
w0ady's Avatar
fgc moderator
a kid in 1 of my stl car clubs built it and i bought it off him.
Old May 29, 2008 | 10:06 PM
  #42
Hlarious TF2 Vid
Old Jun 2, 2008 | 11:50 AM
  #43
w0ady's Avatar
fgc moderator
bump. anyone with an extra pci-e card around town?
Old Jun 2, 2008 | 01:43 PM
  #44
SFLG35's Avatar
FGC President
i have one lyndon
ill let you borrow it if you bring me my sub and come pick the card up.
its an eVGA eGeForce 6600
Old Jun 2, 2008 | 04:45 PM
  #45
Hey Dan, want to respond to my PM?!
