Headlight Haze Question
Old Jun 4, 2008 | 04:32 PM
iamericgee's Avatar
does anybody know of a certain product to clear the haze off the headlights ?
is it something i can buy at discount auto parts ?
Old Jun 4, 2008 | 05:35 PM
Dakkerz's Avatar
Yeah, try Meguire's Plastix.
Old Jun 4, 2008 | 06:13 PM
mt7rabbit's Avatar
^ +1 that stuff works pretty well. If you have a buffer it makes the job much easier.
You can purchase it at a local auto parts store.
Old Jun 4, 2008 | 10:54 PM
G35sedan03's Avatar
you an also use break fluid. very cheap and will do just as good of a job as the plastix. you probably got some in your garage.
Old Jun 5, 2008 | 02:10 AM
mdemonte's Avatar
or u can do the wet sanding Eric-san
Old Jun 5, 2008 | 06:33 AM
kgreene's Avatar
Meguire's Plastix.............
Old Jun 5, 2008 | 06:57 AM
G35sedan03's Avatar
i used this type of kit before. it's time consuming compared to using the plaxtix or brake fluid and it comes out about the as the other two methods. Also if some of the liquid gets on your paint, it could ruin it.
Old Jun 5, 2008 | 07:56 AM
Gilley's Avatar
Be careful not to get brake fluid on your paint. It will ruin the paint.
Just last night I used some Zaino Z-PC http://www.zainostore.com/Merchant2/...roduct_Count=6 with my drill and buffing pad and removed the haze on mt sedan's headlights in less than 30 seconds a headlight.
While you're ordering the Z-PC, go ahead and get some other Zaino stuff because it's a flat rate shipping fee no matter how much you order.
Old Jun 5, 2008 | 08:29 AM
iamericgee's Avatar
thanks for all your help guys !! i have been using just normal car wax and it kind of works but it doesnt last long ! Meguire's Plastix is this a wax also ?
Old Jun 5, 2008 | 08:54 AM
w0ady's Avatar
fgc moderator
ya its just a wax really. rub it on, let it haze then wipe off. lasts a week or 2 depending.
you know its bad when they have a pic of our cars on them.
Old Jun 5, 2008 | 10:01 AM
mt7rabbit's Avatar
I did not know you could use brake fluid, how long does it last?
Old Jun 5, 2008 | 12:56 PM
Gilley's Avatar
I wouldn't use brake fluid. It's too risky getting some on your paint.
The Zaino Z-PC is slightly abrasive (it's made to work on paint to smooth it out) and actually removes the haze instead of filling in the rough places with wax.
Old Jun 5, 2008 | 02:13 PM
iamericgee's Avatar
can i get zaino local? or only thru internet?
Old Jun 5, 2008 | 05:36 PM
SKosto's Avatar
From what I understand Zaino can only be bought online, they stopped in store sales a bit ago.
Old Jun 5, 2008 | 07:02 PM
G35sedan03's Avatar
it lasts probably as long as the plastix does since i've used them both. To answer gilley's concern, i just dab it on a terry cloth in a small area of it and begin in the middle of the headlight and work my way out. paint is good, but just like anything that could be abrasive to the paint, just be extra careful.
