yo guys ! it me again with another dumb question!
Old Aug 5, 2008 | 01:38 PM
iamericgee's Avatar
Angry yo guys ! its me again with another dumb question!
what the eff ! i have all this noise coming from the rear of my car it like a clicking noise as if some thing needs to be greased or lubed , i heard of this problem before i think with other g,s so anybody know what the deal is on how to fix it ?
Old Aug 5, 2008 | 01:39 PM
DRA-G35-ON's Avatar
I think if you take it to the dealership, they grease & tighten it.
Old Aug 5, 2008 | 01:40 PM
iamericgee's Avatar
for free ??
Old Aug 5, 2008 | 02:06 PM
stpdevil's Avatar
It's a tsb... so I assume it should be under warranty?
I had the same problem a couple years back and lokey fixed it for free.
Old Aug 5, 2008 | 02:11 PM
DRA-G35-ON's Avatar
Originally Posted by HYDROERIC2003
for free ??
I'm not sure. I've heard of some people have it done for free and others pay like $300
Old Aug 5, 2008 | 03:29 PM
JC-6MT's Avatar
I had the same issue after I installed my sways but I greased it pretty good.
SFLG35's Avatar
FGC President
depends if the car is under warranty or not.
its the axle clicking problem. i got a new half shaft on mine a few years ago, when my car was under warranty.
Old Aug 5, 2008 | 03:36 PM
_jb's Avatar
_jb
Photographer
There is a TSB for it, but I doubt your '03 is still under warranty.
I had it done on mine. You might want to give Lokey a call and see. Maybe it falls under the longer driveline warranty and they will still do it. Can't hurt to ask.
It also might be a good idea for them to look at it in case it is not what we all think it is. It could be some other problem that might be more dangerous or expensive to fix. Be good to get it checked out.
Old Aug 5, 2008 | 04:12 PM
LokeyInfiniti's Avatar
Hello.
If this is indeed the axle issue with the TSB mentioned by a few other members above, it would be covered by your Basic 4 year/60,000 Mile Warranty. This is not covered by the vehicle's 6 year/70,000 Mile Powertrain warranty. In the TSB, the axle hardware is replaced and the axle splines are thoroughly greased.
Old Aug 5, 2008 | 04:19 PM
iamericgee's Avatar
does anybody know how to turn back the odometer !! just kidding !
Old Aug 5, 2008 | 04:22 PM
Invalid_User's Avatar
just go in reverse
Old Aug 5, 2008 | 04:32 PM
w0ady's Avatar
fgc moderator
try the dealership anyway?
Old Aug 5, 2008 | 05:01 PM
Dakkerz's Avatar
even if you manage to turn back the odometer you can't turn back time on the 4 yr warranty
Old Aug 5, 2008 | 05:05 PM
G35sedan03's Avatar
Originally Posted by LokeyInfiniti
Hello.
John, what exactly does the "powertrain" warranty cover? what major components are covered by that. when i think axle, i think part of the powertrain of the vehicle. please clarify.
Old Aug 5, 2008 | 11:33 PM
Gilley's Avatar
According to the 2003 Warranty Booklet, as posted on the Infiniti website, the following is covered under the 6 year/70,000 mile Powertrain Warranty.
http://www.infiniti.com/ownership/warranty.html
POWERTRAIN COVERAGE
• The Powertrain coverage period is 72 months or 70,000
miles, whichever comes first.
• This warranty covers any repairs needed to correct defects
in material or workmanship.
• Powertrain coverage includes components listed below,
supplied by NISSAN, except for those items listed under the
caption “WHAT IS NOT COVERED.”
ENGINE - Cylinder heads and block and all internal parts, rocker
covers and oil pan, valve train and front cover, timing chain and
tensioner, oil pump, water pump and fuel pump, fuel injectors,
intake and exhaust manifolds, flywheel, seals and gaskets.
TRANSMISSION AND TRANSAXLE - Case and all internal
parts, torque converter and converter housing, automatic
transmission control module, transfer case and all internal
parts, seals and gaskets, clutch cover and housing, and electronic
transmission controls.
DRIVETRAIN - Drive shafts, final drive housing and all
internal parts, propeller shafts, universal joints, bearings, seals
and gaskets.
RESTRAINT SYSTEM - Air bags and related electronic control
systems.
http://www.infiniti.com/pdf/ownershi...ranty_2003.pdf page 4.
This is what the manual calls "WHAT IS NOT COVERED" on page 5.
WHAT IS NOT COVERED
DAMAGE, FAILURES OR CORROSION DUE TO ACCIDENTS,
MISUSE OR ALTERATIONS
This warranty does not cover damage, failures or corrosion
resulting from:
• Accident, theft, fire, driving through water (including engine
water ingestion) or misuse. (Proper use is outlined in your OWNER’S
MANUAL.)
• Alteration, tampering or improper repair.
• Glass breakage, unless resulting from defects in material or
workmanship.
• Installation of non-Nissan approved accessories or components.
• Improper installation of any Nissan approved or aftermarket
accessory or component.
ALTERED OR UNCERTAIN ODOMETER MILEAGE
This warranty does not cover repair of any vehicle or any part of a
vehicle on which the odometer has been altered, or the odometer
repaired or replaced, and the actual vehicle mileage cannot be
correctly and readily determined.
SALVAGE TITLE
This limited warranty does not apply to any vehicle, and is rendered
void if the vehicle is (or ever has been) issued a “salvage” or similar
title under any state’s law; or has ever been determined to be a “total
loss” or equivalent by any insurance company, such as by payment of
a cash payment of a claim in lieu of repairs because of a determination
that the cost of repairs exceeded the actual cash value of the vehicle.
DAMAGE, FAILURES OR CORROSION FROM
ENVIRONMENTAL CONDITIONS
This warranty does not cover damage, failures or corrosion resulting
• Stone chipping, chemical fallout, tree sap, salt, hail, windstorm,
lightning, flood or other environmental conditions.
• The items listed below are not covered under corrosion coverage
(perforation from corrosion)
- Exhaust system components.
- Corrosion other than perforation, such as cosmetic or surface
corrosion due to defects in material or workmanship. This is
covered under the Basic Coverage of the New Vehicle Limited
Warranty.
DAMAGE, FAILURES OR CORROSION DUE TO LACK OF OR
IMPROPER MAINTENANCE
resulting from:
• Lack of performance of proper maintenance services as outlined
in your Owner’s Manual.
• Use of improper or dirty fuel, fluids or lubricants.
• Use of parts not equivalent in quality or design to parts
supplied by Nissan for use on Infiniti vehicles.
MAINTENANCE SERVICE EXPENSE
This warranty does not cover normal maintenance services as
specified in your Owner’s Manual such as wheel alignment,
headlight aiming, replacement of filters, lubricants, coolant,
worn clutch discs and brake pads.
SEAT BELTS, TIRES AND EMISSION CONTROL SYSTEM
Seat belts, tires and the emission control system are covered
by separate warranties.
