check engine light
Old Sep 3, 2008 | 11:54 AM
ltorres781's Avatar
guyz.. i remember havin startin the car... and my slip light... my vdc light and the service engine light(which is what is still lighting up.. not the check engine light).... but i then realized that i didnt plug in the mas sensor on the intake... so i plugged it back in and the slip and vdc lights went off.. just not the service engine soon light.. could that be the case? do i just need to reset it.. or could it be that i havent put rubber plugs on the 2 radiator lines that i joined wit the new elbow connector.. i just taped them for up til i get the chance and get the rubber plugs
Old Sep 3, 2008 | 11:57 AM
iamericgee's Avatar
thats possible but have discount reset it for you!
Old Sep 3, 2008 | 12:09 PM
ltorres781's Avatar
thatz the name of the shop.. discount auto ?
Old Sep 3, 2008 | 12:17 PM
iamericgee's Avatar
YUP ! discount auto parts there everywhere ! or advanced auto parts too they do the same thing ! i go there now and then to get my check engine light reseted too i have a bad co2 sensor and it acts up once in a while !
Old Sep 3, 2008 | 12:20 PM
ltorres781's Avatar
oh ok... yeah .. ima stop by there in a few.. ill let u know how it goes...
Old Sep 3, 2008 | 02:00 PM
escobar929's Avatar
if thats the case then you just need to reset the ecu, search the forums on how to do that
Old Sep 3, 2008 | 04:08 PM
ltorres781's Avatar
went to advanced and it wuz cuz of my mas sensor and intake.. came on becuz i hadnt plugged in the sensor when i started the car... but about restarting the ecu... i've read about the battery disconnect method and pumpin on the gas holdin or something like that.. whatz the best method?
Old Sep 3, 2008 | 04:14 PM
_jb's Avatar
_jb
Photographer
If the guys at Discount Auto reset the codes and the SES light no longer comes on... you are good to go.
Don't worry about resetting the ECU.
Old Sep 3, 2008 | 05:07 PM
ltorres781's Avatar
yeah i figured that.. but i've read up that the reset helps bring it back to factory set up... bein that the car gets use to driving style of the one driving it.. and i bought mine used.. or is that just bs
Old Sep 4, 2008 | 11:21 AM
_jb's Avatar
_jb
Photographer
The ECU adjusts itself (sometimes called learning) so that your engine runs close to its original parameters. The ECU's OEM mission is to make the engine run within the emission levels it was designed for. This learning phase is widely misunderstood and usually doesn't add any horsepower. That's why lots of people reset their ECU before they make a dyno run.
The plan is to get a tune and set the ECU targets to levels that will help your performance. That way the ECU learns towards the settings you want.
Old Sep 4, 2008 | 02:03 PM
ltorres781's Avatar
thanx for the clarification jb
Muski_G
Dec 1, 2023 11:11 AM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
