quick help with belts for UR pulleys
Old Feb 19, 2009 | 02:27 PM
r10apple's Avatar
My belt has suddenly decided to take a crappola and Infiniti doesn't wanna touch the car. This leaves the replacement up to me.
I cannot find my old UR box and pulley and such in my attic and have been unable to find the exact part number for the Gates belt. Below is what I found, but does anyone know if the "high performance" belt listed below is the smaller, v shaped belt or just a 'better' belt the same size as the OEM? The guys at Napa don't know, Nissan doesn't know and neither did Velocity Trends (Jeremy appears awol, too).
If you know the correct Gates part number to use with the UR pulley set, that would be BEST OF ALL!!!
Thanks...
Alt. & P.S. Automotive V-Ribbed Belt (Standard) K060465
High Performance Automotive V-Ribbed Belt K060465RB (Blue)
A.C. Automotive V-Ribbed Belt (Standard) K040372
High Performance Automotive V-Ribbed Belt K040372RB (Blue)
Old Feb 19, 2009 | 03:46 PM
bigman21035's Avatar
http://www.g35parts.com/9083/osc/pro...roducts_id=139
If you are using the Underdriven pulley set
Old Feb 19, 2009 | 05:41 PM
r10apple's Avatar
I appreciate that and all, but I need a part NOW--and NAPA has Gates belts--I just don't want to waste my time driving back and forth to get the right belt...
I'm gonna buy a few of them in the morning if I don't get a response...they can at least get me the two I've cited...
Old Feb 19, 2009 | 10:04 PM
r10apple's Avatar
Man--you guys SUCK. Of all the people in the world to find this, it was my wife!!!
Crankshaft Pulley Bolt Torque Specifications
• First Step: 29 – 36 ft-lbs. / 348 – 432 in-lbs. / 39 – 49 NM.
• Second Step: The head of the pulley bolt has 6 lines, each representing 60-66 degrees of rotation. Choose one of the lines after completing step 1 then
make a mark on the pulley at that line then turn the the bolt until the line before the original line reaches the mark on the pulley.
New Belt Sizes (The belt sizes used may vary slightly. We recommend the use of Gates brand belts. Belt sizing can vary from belt manufacturer to belt manufacturer)
• Alternator Power Steering and Water Pump Belt: Use Gates K060445 (45 1/4” or 1150MM)
• Air Conditioning Belt: Use Gates K040353 (35 7/8” or 910MM)
* New belts will stretch naturally over the first few hundred miles so belt retensioning may be required if you hear belt squeal. Prolonged lack of
retensioning may cause irreversible damage to the pulley voiding the warranty. If a different size belt/s work better on your vehicle please let us
know the manufacturer and size of each belt/s used. You can contact us by phone or e-mail through our web page. Thank You!
Old Feb 19, 2009 | 11:36 PM
Kennedy's Avatar
I was going to say that.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Jcruzg35
Sep 26, 2015 04:47 PM
