Found a BBK on ebay that seems a lil too cheap....
Old May 13, 2009 | 01:31 AM
AS007's Avatar
http://cgi.ebay.com/ebaymotors/Big-B...1%7C240%3A1318
I know Wilwood makes good brake kits, but that is really cheap no? Do you think this is legit?
Old May 13, 2009 | 02:54 AM
daE_35's Avatar
Thats only the front I believe....
Old May 13, 2009 | 02:58 AM
Gu3s5who's Avatar
wow... my mom always said anything that looks too good to be true probably is... thats all i have to say about that
Old May 13, 2009 | 02:59 AM
Gu3s5who's Avatar
Yeah but even the fronts for that kit would be over $1000
Old May 13, 2009 | 05:53 AM
w0ady's Avatar
fgc moderator
if i remember right, the problem with these kits are they're universal and arent ALL wilwood parts or something. stick with kits made for these cars. a good cheaper option is buying a set of g37 akebono brakes.
Old May 13, 2009 | 08:56 AM
WhosUrBuddiee's Avatar
I believe the G37 akebono brakes are bigger. Plus you know they will work
Old May 13, 2009 | 09:06 AM
Kidcane's Avatar
You will get what you pay for. +1 on G37 brakes for the money.
Old May 13, 2009 | 09:35 AM
escobar929's Avatar
exactly, think they were all wilwood parts but like you said its universal, meaning it was designed for any specific car. so the performance might be worse than oem
Old May 13, 2009 | 10:41 AM
AS007's Avatar
http://cgi.ebay.com/ebaymotors/Kspor...QQcmdZViewItem
Anyone heard of Ksport brakes before?
Also where can you buy the akebono g37 brake kit?
Old May 13, 2009 | 10:44 AM
They sell it on the forums. Check vendors section
Old May 13, 2009 | 10:46 AM
escobar929's Avatar
http://www.conceptzperformance.com/C...665.205.135.35
Old May 13, 2009 | 11:11 AM
AS007's Avatar
Would installing just the front Akebono brakes on my 05 sedan and leaving the stock rear brakes offset the brake balance, or would it be ok?
Old May 13, 2009 | 01:29 PM
Kennedy's Avatar
will g37brakes work on the Z?
Old May 13, 2009 | 01:46 PM
Kidcane's Avatar
^^I would think so, maybe different mount. They 370 has the same brakes.
Old May 13, 2009 | 01:59 PM
Yes they are the same. You can actually buy the Akebono brakes with Nissan lettering instead of Infiniti.
No it wont mess up the brake bias, they are already front biased to begin with.
