going to orlando infiniti tuesday, wish me luck!
Old Sep 10, 2009 | 08:08 PM
iamericgee's Avatar
i had a problem with my dealer but im going to stay quiet on this one !!!!
Old Sep 10, 2009 | 08:11 PM
Invalid_User's Avatar
I had this same problem too, it is difficult for me to fill up without having this happen.
Old Sep 10, 2009 | 10:04 PM
JR350z08's Avatar
Originally Posted by G U LATER
I HATE orlando infiniti along with universal nissan
Universal Nissan is the worst place to bring your car.... there service writers dont know there own ba!!s go if you showed them...
Old Sep 10, 2009 | 10:21 PM
Dubi2087's Avatar
They are the ones who burnt my Clutch and told me I needed a new clutch and flywheel setup and they wanted $3,000 for it. I laughed at them and went to performance factory.
Old Sep 12, 2009 | 12:45 AM
Jamaica2G's Avatar
Originally Posted by Gilley
OI has heard of the problem. They replaced the tank and bucket on my sedan a couple of years ago because of it. The sedan still has that problem every now and then.
I have learned that once it clicks off (and the tank isn't full) start pumping slowly by barely squeezing the pump trigger and keep slowly squeezing it until you're all the way open.
+1 to Gilley's solution.
Just start off slow - thats all she wants!
Old Sep 12, 2009 | 12:03 PM
Nightm4re's Avatar
I was lucky and got sarah as my adviser (someone who veronica recommends).... and i called back and requested Jason to be my tech, and they said "sure, he will be your tech that day." so yay for good service! haha
Old Sep 12, 2009 | 05:52 PM
ishiftinheels's Avatar
Teh Redhead Moderator
I was actually just there today at 2, getting Jason's opinion of my transmission. The diagnosis is not good and I don't want to talk about it because it makes me sad. But I'm glad you got that worked out Chris, looking forward to hearing how it goes Tuesday.
Old Sep 13, 2009 | 12:01 AM
Kennedy's Avatar
is it blown or clutch? my trans grinds alot but im under warranty stil..
Old Sep 15, 2009 | 12:38 PM
Nightm4re's Avatar
everything went well. I had sarah as my adviser and jason was my tech. Jason knew exactly what to do because i watched him pretty much do everything on my car...
only one complaint. last time i was there, they asked me if i wanted the headlight recall done. Sarah tried to pull a fast one and she just put it in there... i caught it and told her "no, my headlight cutoff is fine, no need to fix something if it isnt broken"
and i found out that my tires have 10/32 tread left... idk if thats good or bad.
and my brakes are shot.. fronts are ok (6mm) but my rears are bad (3mm)
so looks like im upgrading the brakes..
Old Sep 15, 2009 | 01:09 PM
w0ady's Avatar
fgc moderator
10/32 is fine. your tires should have a wear bar in between the treads - when you tread is down to the same height then you should start looking into new tires. i replaced my rears around 2/32.
Old Sep 15, 2009 | 01:18 PM
Gilley's Avatar
You can change the brake pads yourself and save a lot of money.
Old Sep 15, 2009 | 01:22 PM
10/32 is roughly 1/3 if you think about it. You should be fine for a bit longer. I got new tires when i was at 2/32 as well. Glad everything worked out for you today. Jason is the best.
Old Sep 15, 2009 | 02:49 PM
Nightm4re's Avatar
ah ok, ive had these tires on the rims for a year and a half now. ill just hold off and get new tires around summer time.....
i am going to do the brakes myself.. im gonna price match and see if its worth getting better pads, the OEM pads are fine for me i think...
Old Sep 15, 2009 | 08:21 PM
Eddie Z's Avatar
I'm happy to hear you had a pleasant experience with us.
My name is Eddie, and I work in the parts department at Orlando Infiniti. If you need a better price on those pads shoot me an instant message.
And as far as the headlight recall, our repair order system is designed to automatically populate parts on a ticket for any outstanding recalls that need to be addressed. When Sara entered your vin on the computer, it noted that the headlight recall was never done and billed out the parts on it's own.
Old Sep 15, 2009 | 08:33 PM
  #30
w0ady's Avatar
fgc moderator
years and a half? how many miles are on them?
