Lowering plan.... Any flaws?
Old Nov 30, 2009 | 09:27 AM
813G-WHiP's Avatar
coilovers are fine for dd.. i have a sedan on coils.. i have rear camber arms but waiting to get the front arms to put everything in. i would honestly save for everything that you want and not get stuck with something that you are going to second guess later. i'm glad i went with coilovers!!
Old Nov 30, 2009 | 10:16 AM
ishiftinheels's Avatar
Teh Redhead Moderator
Originally Posted by Gilley
350Z S-Techs and SPC kits front and rear are a good plan.
+1, that's what I did.
SPC > Ichiba
Originally Posted by Nightm4re
U think I'll need the spc front AND rear kit?
I didn't get the front kit, just the rear camber arms and toe bolts.
Old Nov 30, 2009 | 10:59 AM
Nightm4re's Avatar
SPC > Ichiba
Did u get an alignment yet? Could they get the fronts back into spec?
Old Nov 30, 2009 | 12:44 PM
Nightm4re's Avatar
also, noone has commented. Nothing too bad about cutting the fenders rather than rolling them? I figured i would be safer cutting since rolling has a tendency to crack paint if not dont correctly
Old Nov 30, 2009 | 04:09 PM
813G-WHiP's Avatar
if you do it right it won't crack
Old Nov 30, 2009 | 04:54 PM
Kidcane's Avatar
cut.....roll....whatever. 6 in one and half dozen in the other if done right.
Old Nov 30, 2009 | 05:17 PM
SFLG35's Avatar
FGC President
you dont need front arms, people just like to make you think you need front arms.
i had some on my car and took them off after while and now they are sitting in the garage.
so if anyone wants some kinetix front camber arms, let me know
Old Nov 30, 2009 | 06:45 PM
nghiars's Avatar
if you want an SPC and want to save some money... order an Eibach one (made by SPC-i bought an Eibach rear camber/toe kit and was stamped with SPC)
Dont forget shocks!! tokico hp blues aren't too pricey and should be ok. I would look at 350z shocks/struts since you'll be lower then OEM G height
Im on tanabe DF210 and tokico d specs(these have dampning adjustment)- I would possibly go with Swift If i did it again since it has the same drop as my DF210s but are a bit stiffer.
Old Nov 30, 2009 | 07:18 PM
Nightm4re's Avatar
Would my stock sport shocks blow? If so, after how long? I wasn't plnning on doing shocks also...
Old Nov 30, 2009 | 09:03 PM
Kidcane's Avatar
I have seen people go 10's of thousands of miles with stock shocks. I dont know anyone that has blown theirs but I have heard stories.
Old Dec 1, 2009 | 12:05 AM
oOmikeyboy's Avatar
Florida G35 Club, Premier Member
sounds like a plan to me. coils CAN be daily driven, i do it myself. Rear camber kits are normally what everyone does, but fronts i dont bother. I have had no issues so far, but it is pretty cambered.
I think the guy told me as long as both sides are cambered evenly it will be okay. Watch out for toe in/out, thats what eats tires up.
Old Dec 2, 2009 | 04:46 PM
Nightm4re's Avatar
I found my spec sheet from when i had the car aligned LAST december.... after i got these new wheels and tires put on.
Note- my tires have worn evenly for the past 13K miles or so...
Front Left-
-.8 camber
8 caster
.02 toe
Front Right- -1.5 camber
8.1 caster
.06 toe
Rear Left
-1.7 camber
.09 toe
Rear Right
-1.5 camber
.10 toe
Now, you guys tell me whats wrong with the alignment...
Old Dec 2, 2009 | 05:41 PM
Demonteverde's Avatar
Moderator
Eventually they will. It really depends on the drop that you have. If you are running something like Tanabe DF210 (this is what Eldgebroni has on his car) or Eibach Sportline (Hydroeric had this on his car), you will eventually blow out the the shocks quicker than with Stechs due the more aggressive drop.
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
