Help with lowering please (Orlando)
Old Mar 1, 2010 | 08:52 PM
blAk mAx's Avatar
i need some dremmeling done and a lower drop
Old Mar 1, 2010 | 10:06 PM
dmus's Avatar
I see u have an ichiba kit. Did u install it without the dremmelling for the toe bolts? Is that affecting ur toe hence the reason u need to dremmel? Or are u installing the kit for the first time. Just curious.
Old Mar 1, 2010 | 10:21 PM
Invalid_User's Avatar
If you buy a Rear camber kit and dont dremel the holes for the toe bolts then might as well not even buy the rear camber kit.
Old Mar 1, 2010 | 11:34 PM
blAk mAx's Avatar
b2auto installed the camber kit without dremmeling the toe bolt holes and putting the new toe bolt in the wrong place.. i dont have a garage and cant work on my car where i live.. my rear camber is -2.1 and -2.0
Old Mar 1, 2010 | 11:54 PM
dmus's Avatar
Ahhh I see, that sux man. I also noticed u on are on springs, 350z s-techs. 350z sportlines is the lowest ive came across for springs with a still decent ride. 350z dudes swear by them too. May give u another .3"-.5" drop over the s-techs. Other than that probably coilovers
Old Mar 2, 2010 | 08:08 AM
ishiftinheels's Avatar
Teh Redhead Moderator
Dremeling isn't so bad. When I get to work I will link you to my post about which dremel bit to use.
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
