My JWT clutch after 9,000 :(
Sep 27, 2010 | 08:29 PM
i had the same problem, clutch and flywheel burnt after only a year of driving.
so yours was caused from the master and slave cylinders?
i had a leak in the hose for the slave cylinder but it was replaced and no more leaking, they said the master and slave cylinders were fine.
any more info on the cause?
Reply 0
Sep 28, 2010 | 07:36 AM
Man I wish I knew. I just suspected the Master and slave due to a few pedal issues. I really don't know why it truly failed. Except I'm out of a lot of money on a product that should of lasted longer. But I will never know the true cause. If it fails early again I may go with another setup. But I have always been a fan of JWT. This sucks though...
Did your JWT clutch come from Concept Z Beebo?
Reply 0
Sep 28, 2010 | 12:50 PM
^ so what's the plan? Another JWT or try something different? I'm thinking ACT...read alot of good things about em.
Reply 0
Sep 28, 2010 | 12:58 PM
Quote: Man I wish I knew. I just suspected the Master and slave due to a few pedal issues. I really don't know why it truly failed. Except I'm out of a lot of money on a product that should of lasted longer. But I will never know the true cause. If it fails early again I may go with another setup. But I have always been a fan of JWT. This sucks though...
yes it came from Concept Z. i ended up getting the OEM Exedy clutch with ACT street light flywheel
Reply 0
Sep 28, 2010 | 04:04 PM
I stuck with the JWT. If it fails I will not go with that clutch again. Honestly I would of not taken the one sent to me by Coz if I knew if there were burn spots present its not covered. What do you expect a premature failing clutch to do??? WTF!!! Thats no warranty! But how can you truly warranty a clutch??? O well lesson learned. If any other issues arise I will be going with another combo.
Reply 0
Sep 29, 2010 | 09:56 AM
Quote: yes it came from concept z. I ended up getting the oem exedy clutch with act street light flywheel
how do u like that setup?
Any different from stock <pedal feel fast rev ups ect.>?
Reply 0
