FGC's Hot August Discussions
So, my car battery was completely dead a few days ago. Had to get a jump from a friend. Ever since then, though, no issues.
Any ideas what would cause it to drain like that suddenly? Only thing that happened since then was driving home the night before through a pretty deep puddle of water when we had heavy rains on Thursday night.
Battery is only about a year old.
Let's see.
Tein Basics (350z/Coupe)
MREV2
PowerLab 3/8" Spacer
Ztube
Stillen HFCs
Ypipe
Megan OE-RS (Sedan)
SPC 2* Camber Shims (Front)
SPC Rear Camber Kit w/ Toe Bolts
NRG Upper Strut Bar
JDM Window Visors
JDM RHD Battery Cover
JDM Bump Style Corners
MREV2
Ztube
Stillen HFCs
Ypipe
Megan OE-RS (Sedan)
NRG Upper Strut Bar
JDM Window Visors
Corners for sedan and coupe same size, right?
Could be an issue with the radio. Usually when there's a problem with it, it will drain your battery very slowly... like you might be ok overnight, but if it's parked for 24+hrs then it'll die. Kinda depends on the battery.
May not be the issue, but it's worth looking into. Any issues with your CD changer?
