Window motor
Old Aug 26, 2011 | 01:48 AM
VQ35_p0w3r's Avatar
Window motor
How much does a driver side window motor cost for a 04 coupe? Mipounes finally crapped out.
Old Sep 6, 2011 | 12:09 PM
PJ_'s Avatar
PJ_
did you try cleaning it out? I cleaned mine out 3 years ago and they still function fine now.
Old Sep 6, 2011 | 12:50 PM
cramHead's Avatar
how would go you about cleaning out the window motor? ..degreaser?
Old Sep 6, 2011 | 12:54 PM
alfhasg35's Avatar
takes about an hour to clean.. there is a do it yourself on this forum. or you can buy a new one for 180 from oc infiniti.. well. that's what it costs at riverside infiniti and everyone that used to work there now works at oc infiniti.. Call Rick there..
Old Sep 6, 2011 | 06:35 PM
PJ_'s Avatar
PJ_
I just used a q-tip and some rubbing alcohol. not sure if the rubbing alcohol was safe, but still works so, i'll go with a yes .
Old Sep 7, 2011 | 10:39 AM
Evil Wayzz's Avatar
Heres a few iPhone shots from when I fixed mines.
I was later told its not a good idea to remove the metal holder from the bottom bolts....
Used rubbing alcohol & tooth brush to clean plus q-tips to clean the inside of the motor out.
I started this task at 1am finished at 4am and was at work on-time at 9am.....
Old Sep 7, 2011 | 04:56 PM
orl-g's Avatar
buy from rockauto.com
got mine from there approx $120 but then u get som back wen u send in old one (c0re)
Dallsinghjr1
Sep 17, 2023 11:25 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
