Tires
Old Sep 11, 2011 | 11:02 AM
G35sedan03's Avatar
Originally Posted by w0ady
tried toyo t1-r's, nitto invos, yokohama s.drives and hankook v12s. v12s are still my fav so far.
still waiting on a response.
wow can you get your panties loosened up a bit, can a dude go out for the weekend. Out of the ones you mentioned, i've tried the t1-rs along with the v-12 and the vreds. simply put the engineering behind it. the v12s resin coating is not part of the entire compund, throught the tire, while a very effective resin for dry traction, it suffers in wet handling. the vreds channel much more water and have better wet traction. the sidewall flexing i have noticed is much more responsive with the vreds when cornering hard. i feel more in control when taking those corners. while the sedans do suffer from oversteer, i found my rear section much more in control with the vreds on. dry traction is better as well, the silica compound used on the vreds is very grippy and even with a 260 treadwear rating, so far they are on pace to last longer than my v12s.
oh yeah do i have a dexter tire laboratory in my house? no.
they are both greatly priced tires for the market and competition around them. both very capable when pitted against its competition but the vreds pulls ahead with the added wet handling, sidewall response and overall grip. additionally, they are fairly lightweight. for a guy like you who hits the track, every ounce counts. in 275/35/19 the v12 are listed around 29lbs (i think 28 is more accurate), the vreds in the same size are about ~26.4lbs.
i would say try them as your next set, i think you would appreciate them. they are about the same price if you shop around.
Old Sep 11, 2011 | 08:18 PM
Sen's Avatar
Sen
I haven't used too many different types of tires. Mostly just going between fk452s and v12s. It seems to me, too, that the v12s wear out faster.
Old Sep 11, 2011 | 11:33 PM
Dubi2087's Avatar
All of the tires mentioned are with in the same price category as well as Treadwear, longevity and handling. They are all UHP (Ultra High Performance) tires. So they will all perform (some what) similar but with each having their own top characteristics.
The Toyos are way over priced for what you get out of them. They are garbage in the rain and don't last.
The Invos are ok. They don't handle very good in the rain.
The S Drives are pretty good. They are good in the rain, dry and longevity wise they are not bad they lasted me 30,000 miles.
The V12s are almost like the S drives but with a little bit better grip.
The Vreds are good too but they are harder to find (unless ordered online). The asymmetric directional tread pattern is what makes them so good.
Old Sep 11, 2011 | 11:35 PM
Dubi2087's Avatar
Originally Posted by Sparda1123
So i looked at my rear tires this morning and noticed it’s about that time..... A year and 2 months these Hankook ventus V12's have served me good. Now i just need rears but if I’m going to buy tires I’m gonna get a set of 4 and get new wheels to. So my question is anyone know of a place with good prices or has a hook up? I can get a set of V12s in the size i want em for about 700 online but i didn’t know if i can get better tires/ prices anywhere else. Also i planned on keeping my OEM 19s as backups so i wanted to keep the TPMS in there, what did you guys do about your TPMS with aftermarket wheels? I want to try and get another set of sensors if they’re priced ok that way i don’t have the "idiot light" on all the time. Also I’m posting this while I’m at work so if I’m a bit slow on the response i apologize in advance.
Give me a call and let me know what you are looking to get out of the tires and I will lead you in the right path. I will be at the meet on Wed if you want to talk there also.
Old Sep 12, 2011 | 12:27 AM
w0ady's Avatar
fgc moderator
appreciate the feedback. too often people throw out blanket statements like your original with nothing to back it up. this was a much more informative post than your first. ill have to look into them although i just bought a new set of v12s. i havent found my v12s to be lacking in wet grip or sidewall response even when i do push them but if its a noticeable improvement then thats what matters.
edit: nevermind they dont make a 285/35/19.
Old Sep 12, 2011 | 09:14 AM
Sparda1123's Avatar
Thanks guys for the positive responses! Dubi il give you a call on lunch today. Ive been a bit busy over the weekend and hadnt had the chance to check the forum. Also Dubi what kind of driving do you mainly do to get 30k out of the V12s? Any track duty/ aggressive driving duty? I feel im a VERY aggressive driver not to mention i go to the track almost once a month if not more im surprised theyve lasted this long but i got about 9000 miles on mine now.
Old Sep 12, 2011 | 09:37 AM
G35sedan03's Avatar
yeah that is the one thing i am waiting from them. a 285 would be nice.
Old Sep 12, 2011 | 09:51 AM
Sparda1123's Avatar
Woady what size you running now? When i get the new wheels i was going with a 10.5in rim in the rear and 9.5 up front and thinking about 275/40/19 and 255/40/19 i havent decided the off set yet but i have the choice between 0, 12, and 22.
Old Sep 12, 2011 | 09:56 AM
G35sedan03's Avatar
the 0 offset will be very aggressive and tight. some folks are running that. the 12 is safe, it will look good. a 285 will fit nicely in the rear. you may want to go with 285/35 instead of a 40 sidewall. the overall circumference might be above what's tolerable for the vdc. you can check that with the wheel size calculator.
Old Sep 12, 2011 | 10:07 AM
PJ_'s Avatar
PJ_
0 ... do it... hahaha. i guess i cant really talk. im running 19x12+0 on my Q right now. Looking for new tires .... gonna go a little more conservative 19x11+10
Old Sep 12, 2011 | 10:29 AM
Sparda1123's Avatar
So the 12s should do it all around at stock height and when i lower on coils about 2in?
Old Sep 12, 2011 | 01:56 PM
PJ_'s Avatar
PJ_
rimtuck.com is a very good reference site for wheel/tire sizes
fyi, folks posting on there are running lots of negative camber and have done fender work.
Old Sep 13, 2011 | 01:58 PM
Nightm4re's Avatar
I also need new rears. I am running 285/30/20 in the rear right now... I like the V12s because of the price... can anyone recommend a good place to look at the vred that would have a good price?
Old Sep 13, 2011 | 02:18 PM
Sparda1123's Avatar
Hey Chris i talked to Dubi he gave me about the best price i can find right now give him a call!
Old Sep 13, 2011 | 02:24 PM
  #30
Nightm4re's Avatar
Alright, ill give him a call tomorrow when i get the opportunity.
