calcul8
I can haz potato?
close
- Join DateJun 2006
iTrader Positive Feedback100
iTrader Feedback Score(4)
- My Ridesabertooth tiger
Liked:1,024 Times in 796 Posts
Quote:
Nope, work sucks alreadyOriginally Posted by bluedevils95
enjoying your day?
ishiftinheels
Teh Redhead Moderator
close
- Join DateMay 2008
- LocationOrlando, FL
iTrader Feedback Score(5)
Liked:242 Times in 174 Posts
Hi Nate!
calcul8
I can haz potato?
close
- Join DateJun 2006
Quote:
What would you guys do if you found someone doing this to your G?
What any prudent, law-abiding citizen would do:Originally Posted by ilovez33
Nothing....... What would you guys do if you found someone doing this to your G?
Golden_Shower
close
- Join DateMar 2010
- LocationBlow Buddies SF
iTrader Feedback Score(13)
Liked:272 Times in 222 Posts
I would marry that women and have her do that to my ......Originally Posted by ilovez33
Quote:
lmao
ishiftinheels
close
- Join DateMay 2008
omg hahahaha
Quote:
I'm preeetttyy sure the RH's are somewhere between +22 to +25 all around.
Edit: and the RH's are 19"
Yea +32 and +45 is a really high offset for the v35 coupe. Maybe it's a good setup for the v36 coupe. I'm sure Chad could chime in on that one.Originally Posted by ishiftinheels
The Vossens are 20x9 +32 and 20x10.5 +45I'm preeetttyy sure the RH's are somewhere between +22 to +25 all around.
Like I said, I think +18ish looks good and is not too aggressive for a 9.5/10.5 stagger. So you probably could get to about that with 25mm spacers at all four corners. If your front is 9.0" (and not 9.5")
Does that sound right? Can anyone confirm?
ishiftinheels
close
- Join DateMay 2008
Thanks Shawn. David has two 20mm and two 25mm spacers for sale, you think I should grab them? The other thing I'm worried about is the fitment of the RH's on the g37. If cambering them in will solve the problem, I'd still need camber arms.
I'm just trying to decide if it's worth buying both spacers and camber arms, or just swap the wheels back to the way they were...
