KPTechnologies Shift Lights
#211
Chuck,
Thank you . . . Thank you for your DIY link. It was extremely helpful. This link is a must. It takes all of the install uncertainties out of the equation. Especially, for someone such as myself.
Daniel,
The Window Up mod rocks big time. It installs very cleanly and works to a fault. It is a must mod in my opinion. This is how our cars should have come from Infiniti in the first place. Thanks!
Daniel,
#212
Originally Posted by andy2434
Chuck,
Daniel,
Daniel,
#214
Originally Posted by klg35
who have installed the shift light on their sedans? need to verify if pin #12(crank sensor/light brown wire) is the same as the coupe........if not, which pin #/color wire is the crank sensor for the sedans, specifically 04 6mts...I'll try to dig this info up in another thread as well............thanks.
According to the 04 sedan service manual the crank wire is brown, but its pin 95. There are three brown wires, just like the sedan. However, the service manual only documented the A/T tranny, so it MAY differ to the 6mt. I don't have any info on the 6mt!
#216
Hey guys, I need some help. I'm looking for someone who has an 2003.5 coupe and has installed the shiftlight. I can't get mine to work. Which wires did you 03.5 owners tap into.
Orange goes to blue/yellow vdc wire
Black goes to vdc black
Yellow goes to black wire w/fuse and to ?
Blue goes to ?
I hooked my black/fuse to the cigarette lighter and I can't find a rpm signal wire. Any help is appreciated.
Blue goes to ?
#217
Blue goes to ?
Blue goes to ?
yellow goes to fuse and the other end goes to the black red wire on teh ignition harness.
blue goes to the crank shaft position sensor wire in pin 13
you can also use one of the other wires that kevin has posted on www.kptechnologies.com/forums
i also responded to your questions on there.
#220
#222
If you could tell what thread to find at kp telling how to use the volt meter, I would be endebted.
#223
4. Mr pharmD - Dan - White - PAID - shipped
13. Philthy - Phil - Blue - PAID - shipped
17. Demonteverde - Ian - Blue - FL - PAID - shipped
KPTechnologies Window Up
3. Whoojong - Whoojong - TX - PAID - shipped
12. 0TRACK5 - carter - CA - PAID - shipped
13. 0TRACK5 - carter - CA - PAID - shipped
17. mborel7052 - Marc - CA - PAID - shipped
KPTechnologies Auto Door Locking
5. Shooter - Roger - PAID - shipped
KPTechnologies Sunroof Controller*
3. 0TRACK5 - carter - ?? - PAID - shipped
6. mborel7052 - Marc - PAID - shipped
7. Demonteverde - Ian - FL - PAID - shipped
9. BocaCoupe - Rob - FL- PAID - shipped
people who have not received their modules or have not contacted me. please let me know when you receive them
thanks
thanks
#224
#225
I'm building up the ambition to attempt this mod again. I have a good power source and have correctly spliced into the vdc switch. I am looking for a signal wire. For owner's of 2003.5 coupes with 6 speeds, what color wire did you use from the ecu harness. I have tried all of the brown wires and found one that had the correct idle voltage, but the voltage did not increase with the rev's. I am probably the only person who can take a simple 2 hour job and turn it into a 12 hour nightmare. Thank you in advance for any help.
