DVD Install
Old Mar 28, 2006 | 10:54 PM
ProjectFusion's Avatar
Florida G35 Club, Premier Member
Originally Posted by twinchell
Yeah, at first this is what I wanted to do as well, but after more thought, I knew I would be playing DVDs at least 95% of the time. So, to me, the memory thing that stores the position of the movie when the car is turned off is more important than the 5% I would be gaming.
Same reason I didn't go with Ps2
Old Mar 28, 2006 | 11:22 PM
suaveyankees's Avatar
mine is in the center counsole also
Old Mar 29, 2006 | 12:11 PM
twinchell's Avatar
or whatever
Originally Posted by ferk
Looks nice I am considering doing the same to my car.
Question: Is there a switch required between the Nav and the DVD player?
If so where did youput it?
Yes, there is a toggle switch that switches between the two. Right now its just dangling, until I decide where to mount it. I am thinking about going to the dealer and getting another rocker switch similiar to the seat warmer buttons. I have 3 slots; two for seat warmers, and the 3rd for the dvd switch.
Old Mar 29, 2006 | 06:34 PM
twinchell's Avatar
or whatever
Another question after watching a few movies: When I crank it up all the way, when the bass hits really hard, the sound seems to almost skip (decreases in volume and everything); any ideas? The video seems to stay stable, because I thought maybe the bass was actually causing the DVD to skip, because it's quite a bit of bass, but doesn't seem to be the case. When I turn the bass down on my subs, it works fine.
Old Mar 29, 2006 | 06:41 PM
0MGHI2U's Avatar
how much did you pay for the tvnavi2go.. did you have to like strip wires and what not? i have and o5 coupe wit navi
Old Mar 29, 2006 | 06:47 PM
twinchell's Avatar
or whatever
It was $125 on a group buy, $140 shipped. There are two options, the non-plug-n-play requires splicing wires, and the plug-n-play you just snap in. I think the plug-n-play is an extra $100 and I believe the 05' is more too.
Old Mar 29, 2006 | 07:03 PM
Real_G's Avatar
An Army of One...
I have the 06 Plug and Play..
Here is a DIY thread on the install (its not 100% plug and play, there is 1 ground wire!)
https://g35driver.com/forums/audio-video-electronics/90513-diy-tvandnavtogo-pnp-2006-g35-coupe.html
Old Mar 29, 2006 | 07:04 PM
Real_G's Avatar
An Army of One...
Check your wires coming out of the DVD to the interface.. sounds like a wire might be loose and is vibrating and breaking connection when bass hits.
Did you twist and tape? Crimp and tape? or solder and tape?
Old Mar 29, 2006 | 08:10 PM
twinchell's Avatar
or whatever
Solder and tape. It only happens with bass, not with like turning or any hard body roll, even takes bumps fine.
Old Mar 29, 2006 | 09:15 PM
KPierson's Avatar
Todd,
I will be sending Dan a few switch modules that will allow you to use your VDC switch to toggle between Navi and video (or anything else you would want to switch), would you be interested in testing it out? It will be a much cleaner install then a toggle switch!
Old Mar 30, 2006 | 11:10 PM
SFLG35's Avatar
FGC President
Yeah, I'll test that **** out. You coming over to install it though, I don't trust Dan, even though I'm posting under his name.
R350k5
Oct 1, 2015 08:41 PM
gatorglaze
Sep 10, 2015 12:03 PM
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
trulegend
Audio/Video/Electronics
Jul 31, 2015 03:37 PM
